diyAudio Sponsor
Old 26th February 2010, 01:55 PM   #41
JoshK is offline JoshK  United States
I've seen it said numerous times that the OS EI KT-90s "killed" in triode. If those were based on the EL519 type tubes, would it follow that the EL519-types would also be glorious in triode?
I ask because the EL519-types are easier to come by and being a diy'er we are not tied to specific pinouts that the KT88 types require.
I am thinking that George's PP KT88 project idea that he has written about might be a good place for these types.
Old 26th February 2010, 02:26 PM   #42
richwalters's Avatar
EH KT90's are the solution. Can recommend them. I'm getting thd figures lower than all the variants of KT88's about and with an extra power bonus. I guess alot depends on the output stage match and especially the screens need to be driven fairly hard (9mA).
richy
Old 27th November 2011, 03:08 PM   #43
Default EHkt90 in simple se
I have a unique stereo. Plate amps driving open baffle 15" woofers below 200Hz driven by my Moscode 600.
Tubelabs simple se in triode mode above that driving Audio Nirvana 10" open baffle.
I set up my dB meter and checked with a sterophile disc the freq response with both KT88 then my new EH KT90 (in the simple se) really no difference in output (not louder). A few frequencies were up (or down) a dB or so but mostly identicle output.
The only change was when I changed to the KT90 I upped the bias (according to my calculations about 43watts plate dissipation= no plate glow)
Tubes are still a little too young to say if I like them better or not, but this little amp shows clear differences in sound from other various tubes I've tried
Paul
Old 29th November 2011, 05:27 PM   #44
rknize is offline rknize  United States
rknize's Avatar
Send a message via AIM to rknize Send a message via Yahoo to rknize
I run mine at around 40+ Watts as well. They have a unique sound as triodes when biased hot.
Russ
Simple SE - Ei KT90? Ty_Bower Tubelab 22 7th July 2009 03:01 PM
KT90 why this ? richwalters Tubes / Valves 8 19th February 2008 01:42 PM
Anyone have accurate charts for a KT90? aletheian Tubes / Valves 1 6th March 2007 06:30 PM
Kt90 Pse Mikewong Tubes / Valves 9 15th February 2007 07:44 PM
Electro Harmonix KT90? georgehifi Tubes / Valves 73 11th February 2007 03:24 AM
Page generated in 0.08872 seconds (69.17% PHP - 30.83% MySQL) with 11 queries
