#11 |
Hi ManUtd,
When it rains .... Okay, so measure the plates, grids and cathode connection to start. -Chris |
#12 | |
Between Pin 4 and 5 i got 2,9V.Pin 6 Rising up to 92V and drops down to 86V.Pin 7 135mV (hmmm!). Pin 8 0,76V. What about pin 2 and 7 are these normal? Could it be leakage in a capacitor? Reg, ManUtd. |
#13 |
Hi ManUtd,
Pins 2 and 7 are not referenced to ground. So this could be perfectly normal for this unit. I looked at the current source reading and want you to reconfirm for me. I calculated a cathode current of 0.88 mA for both sections. That is current starved. The first section is running with a grid voltage of -0.625V and the second section is -0.625V wrt the cathodes. A very low value that supports the low cathode current observaton. There may be a problem here. -Chris |
| Melos SHA Gold Issue | john65b | Tubes / Valves | 6 | 8th March 2008 01:09 AM |
| Melos Ma-111b | jfsebastian | Tubes / Valves | 1 | 6th April 2006 03:25 AM |
| melos gk1 preamps anybody? | stuck.wilson | Tubes / Valves | 1 | 5th October 2005 10:42 AM |
| FS: Melos MAT-180 175 wpc tube amp | Kip | Swap Meet | 0 | 31st July 2003 05:09 PM |
| FS: Melos SHA-1 | Tomo | Swap Meet | 1 | 13th October 2002 04:12 AM |
