| diyAudio Sponsor | ||
Does anyone know of a good tube phono pre-amp that is DIY? and preferably cheap? because I am going to try and build a stereo that is transistorless! and it is only possible if i get a tube phono preamp. Any help is extremly welcome
#2 |
Find Kuei Yang Wang's post on El Cheapo phono stage. A couple of member have built it.
#3 |
This one's supposed to be pretty good:
To be found on www.triodedick.com (Dutch only -check 'projects') |
#4 |
Alexmoose:
Bottlehead offers the Seduction phono preamp. I don't have one, but their Foreplay preamp was a terrific project and sounds too good to be true. Regards, Scott |
#5 |
The cathode resistor of the first mu follower stage is missing!
#6 |
"Find Kuei Yang Wang's post on El Cheapo phono stage. A couple of member have built it."
I built this and its great. Shoog |
#7 | |
http://www.diyaudio.com/forums/showt...?postid=335624 Here This is the schematic is this the illustrious "El Cheapo phono stage"? |
#8 | |
It's the valve El Cheapo, there is an opamp El Cheapo version. I've built the valve El Cheapo and am well pleased with it. There is another thread started by Kofi Anan with a lot of detail on the build particularly the earthing. I found that I needed to build the psu separate from the stage as there was too much noise, but I am using a v.low output cartridge. Kev |
#9 |
That's it alex, on my way to build mine too.
#10 |
Okay, I have identified the "El cheapo" (whoever dubded it that needs a metal) However being a nube to tubes, I of course have some questions that will make me look like an idiot.
What does the number mean after the resistor value in some of the resitors for example 51k1 (bottom left corner) does this imply 1 watt? resistor with a value of 51k ohms? How much current do you think this needs? because the Hammond 269 JX provides 250v (the B+ on the schem) at 60ma for a modest $33.95 from Tubes and more is this enough? What does the capacitor labeled "2u(mew)2" (middle right) mean? I understand way by which capacitors are rated, but what does that mean? What does "MKP" mean? What does "KP-SN" mean? |
| DIY tube phono preamp ? | abacus | Analog Line Level | 2 | 16th September 2008 11:08 PM |
| Tube Phono preamp kit? | ChopperCharles | Tubes / Valves | 4 | 13th March 2008 06:14 AM |
| Are the any tube phono preamp PCB's | regal | Analogue Source | 3 | 27th October 2006 04:45 AM |
| phono tube preamp? | karma | Tubes / Valves | 7 | 4th July 2003 01:19 PM |
| Tube Phono Preamp/Headphone Amp | trustalbini | Headphone Systems | 6 | 14th April 2003 01:41 PM |
| Page generated in 0.10908 seconds (77.02% PHP - 22.98% MySQL) with 11 queries |
