| diyAudio Sponsor | ||
Hello Im building the attached amp in a mono mode and the B+ will be
300 v instead of 350. to keep the preamp voltages and currents the same I calculated the the 27K feed resistor to be now 3333 ohms Does this seem kosher ? Thanks Jeff
"If every one is making wheels , why make wheels ? " Steve Jobs |
#2 |
The voltage difference then is 350-293 = 57V, with 27000 dropping resistor, the current is 2mA.
Now you want to drop 7V (300-293) at 2mA, the resistor is 3500 ohms. Close. |
#3 |
Use switchmode caps for cathode decoupling stages...they make a worthwhile improvement in sound quality. Choose 105°C low ESR types. Soundwise, I find them just as good a tants, esp for 1st stage.
richj |
#4 | |
| Can I get a double check on my cabinet? | saabracer23 | Subwoofers | 23 | 9th June 2009 07:34 PM |
| Check my math? | Jalex420 | Chip Amps | 18 | 3rd June 2006 08:58 AM |
| DIY Sub with DAYTON RSS315HF-4 in progress; Can someone check my math? | bcycle | Subwoofers | 18 | 7th February 2006 10:30 PM |
| Crossover math check | jmikes | Multi-Way | 6 | 13th December 2004 10:30 PM |
| Page generated in 0.08191 seconds (69.22% PHP - 30.78% MySQL) with 11 queries |
