step-up travel transformer for small preamp?
Old 26th March 2006, 06:13 AM   #1
aletheian is offline aletheian  United States
aletheian's Avatar
Default step-up travel transformer for small preamp?
I have seen those small 50 watt 120v to 240v transformers floating around, and I have often wondered if that sould be used to power the B+ of a small preamp. 240v*10mA=less than 3 watts, so I dont see why power-wise it would not work. I don't know if they are current-isolated from the mains, but I was hoping someone here might have some more info.
Heghlu'meH QaQ jajvam!
Old 26th March 2006, 06:15 AM   #2
aletheian's Avatar
Something like this:
Old 26th March 2006, 10:16 AM   #3
Shoog is offline Shoog
Shoog's Avatar
They are usually autotransformers so not suitable.
Check for continuity between the 110V tap and the 240V tap.
Shoog
Old 26th March 2006, 10:17 AM   #4
lndm is offline lndm  Australia
Is that a conventional power xfmr? I used to use something that small for a bias supply.
I guess it would be OK for class A duty. The steady current requirement (especially if used for a class A preamp) would draw little problem from the potentially bad load regulation characteristic of the xfmr. I would probably want a substantial filter capacitance and only ask a few mA from it.
Old 26th March 2006, 06:04 PM   #5
aletheian's Avatar
That is what I figured. I am thinking of experimenting with one running a single 12ax7 tube for the preamp and a 12au7 output buffer, so I would not be drawing more than half a dozen milliamps.
I have seen a few advertised as "isolated" so I suppose they would work.. maybe I'll get a few and see which are autotransformers and which ARE actually isolated.
I usually like to run regulated voltage in my preamps anyway, so I am not overly concerned with poor tranny regulation.
Old 27th March 2006, 12:40 AM   #6
Tubelab_com is offline Tubelab_com  United States
Tubelab_com's Avatar
I have found that the cheapest way to get 240VAC is a Triad N-68X. $11.20 at Mouser and it is good for 50 watts. It has 2 115 volt primaries and 1 115 volt secondary. Turn it around (use the secondary as a primary) and you have a 230 volt center tapped secondary. with a FWB rectifier I get almost 300 volts DC at over 100 mA. They also have a 6.3 VAC 3 amp filament transformer (41FD030) for $6.98.
So you have the power supply iron for $18. With the Edcor $18 output transformers I have all of the iron for a good sounding SE UL amp for $54!
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 27th March 2006, 05:53 AM   #7
aletheian's Avatar
that's a great tip. Thanx. I have to do a Dale resistor order @ Mouser anyway, so I may as well toss one of those on.
step-up travel transformer for small preamp?Hide this!Advertise here!
DIY step down transformer rhapsodee Parts 4 24th May 2009 03:16 AM
Low-end small portable speakers for travel - build or buy? larry_long Full Range 11 30th December 2008 02:52 AM
Step Down Transformer Ropie Power Supplies 3 15th October 2006 09:42 AM
Can I use a step-up transformer as step-up? cviller Parts 5 6th September 2006 06:32 PM
help design SE preamp with mosfet buffer and step-up transformer. AudioGeek Solid State 0 19th January 2005 03:02 AM
Copyright ©1999-2017 diyAudio
