diyAudio Sponsor
Old 24th March 2006, 01:49 PM   #1
Default 4 x PSE EL34
Hello
I am looking for a 20 - 25W SE amplifier an I had seen at following project:
4 pcs EL34 i parallel
BUT, does anybody had tried to build this amplifier. The 2 opt cost €600 in Denmark and that is a lot of money if the sound is bad.
Maby it is better to build a PSE KT88?
Benny
Old 24th March 2006, 02:26 PM   #2
All of Andrea Ciuffoli's designs I have seen on the internet are not going to be inexpensive to build, they either use Lundahl and or custom transformers. Now if you can get iron from another source say Edcor, you may be able to build for far less but your gonna have to send them the info on the iron and see what they say.
El34 PP Vs. El34 PSE alexmoose Tubes / Valves 47 6th September 2006 06:44 PM
My El34 SET alexmoose Tubes / Valves 10 9th May 2006 09:10 PM
EL34 CCS help navin Tubes / Valves 2 25th March 2006 03:59 AM
6L6 vs EL34 resident Tubes / Valves 20 13th October 2004 07:37 AM
Page generated in 0.05699 seconds (69.35% PHP - 30.65% MySQL) with 10 queries
