diyAudio Sponsor
Old 24th March 2006, 11:07 AM   #1
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
Default EL34 CCS help
THe pic attached is the CCS.
A friend assembled the CCS boards and discovered a problem.
The circuit has a "direct connection" between the 6SL7 and the 6SN7 stage. This means the CCS will have about 261 volts at its collector. The current is about 14.5 mA . So dissipation is about 3.8 watts in the MPSA340 used there. This is too much for the MJE340.
Note that if the stage was " ac coupled " with a dc blocking capacitor in between then the cathode would be at just about 7 volts.
FYI...
this is the amp
http://www.diyaudio.com/forums/attac...amp=1136905599
The power supply http://www.diyaudio.com/forums/attac...amp=1100080737
...still looking for the holy grail.
Old 24th March 2006, 11:50 AM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
MJE340 is rated at 20W dissipation (with heatsink). Just add a heatsink with 8C/W thermal resistance or better.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 25th March 2006, 03:59 AM   #3
navin's Avatar
thanks.
El34 PP Vs. El34 PSE alexmoose Tubes / Valves 47 6th September 2006 06:44 PM
My El34 SET alexmoose Tubes / Valves 10 9th May 2006 09:10 PM
4 x PSE EL34 Hojvaelde Tubes / Valves 1 24th March 2006 02:26 PM
6L6 vs EL34 resident Tubes / Valves 20 13th October 2004 07:37 AM
Page generated in 0.08220 seconds (73.38% PHP - 26.62% MySQL) with 11 queries
