power supply for tube preamp
Old 15th November 2002, 01:52 AM   #1
rafafredd is offline rafafredd
Default power supply for tube preamp
Hi.
Im building a tube mic preamp and I would like to know your opinions about the power supply.
Should I use the original power supply rectified with 6X4 miniwatt tube or should I go with the alternate diode one?
What would be the best option?
Old 15th November 2002, 02:00 AM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default TUBE MIC.
IMO take the original one and if you can post a circuit we can even improve that.
You may not like what the diodes do and if you don't have a stiff PSU that's well isolated from the rest of the amplification circuit you're bound to hear it in the recording.
Just my 2 euronickels,
Frank
Old 15th November 2002, 03:57 AM   #3
B-Grade is offline B-Grade
Send a message via AIM to B-Grade
Default Tape OP?
Would this be the Mic pre in the tape op mag?
Old 15th November 2002, 11:50 AM   #4
Default Here goes the original power supply
Note that this is not for a tube mic, but for a tube mic PREAMPLIFIER
Old 15th November 2002, 12:04 PM   #5
Default And the alternate one
Also would like to know if you can tell me the resistence for R6 and R11. Im using 110V. I dont know, but theres a text file that says that this resistors depends on input voltage.
Old 15th November 2002, 12:04 PM   #6
fdegrove's Avatar
Default INVALID ATTACHMENT
The .bmp file you posted doesn't seem to be valid.
Ciao,
I was too fast it would seem.
Works now so ignore my post.
Thanks,
Frank
Old 15th November 2002, 12:05 PM   #7
Default look again
look again
Old 15th November 2002, 12:33 PM   #8
Joel is offline Joel  United States
Joel's Avatar
What's wrong with the first one? Capacitance maybe a bit low, but other than that, looks ok.
Old 15th November 2002, 12:45 PM   #9
fdegrove's Avatar
Default PSU
The tube PSU would certainly benefit from choke filtering and some good quality polypropylenes or PIOs behind it.
The SS one has an extra 48 VDC regulated but what is that for?
I can't see it in the tube PSU.
Cao.
Frank
Old 15th November 2002, 03:00 PM   #10
Default PSU filter
Cao.
Can you porvide more information on how to do it?
power supply for tube preampHide this!Advertise here!
Tube Preamp Module and Power Supply PCB's Geek Swap Meet 47 31st January 2009 08:48 AM
looking for hv power supply kit for car tube preamp tomat Parts 6 7th December 2008 02:48 AM
looking HV pwr supply kit for car tube preamp tomat Car Audio 2 26th September 2008 02:03 AM
WTB:power supply for tube preamp dariusku Swap Meet 0 18th September 2006 06:04 PM
P88 preamp power supply Scribble Solid State 2 23rd January 2005 08:50 AM
