YAPPAP (Yet Another Push-Pull Amplifier Project) - Page 2 - diyAudio
Old 28th June 2006, 02:27 AM   #11
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Hi alex, if you mean LTP or split load- it's hard to explain but it's very smooth sounding without being slow or suffering from dynamics.
Old 28th June 2006, 05:11 AM   #12
alexmoose's Avatar
what does it do to the cost? because it looks like it help make everything a little more simple
Old 28th June 2006, 10:22 AM   #13
diyAudio Moderator Emeritus
ray_moth's Avatar
Cost can be a stumbling-block where interstage trannies are concerned. A good one costs plenty and for maany years they were considered poor. However, there are good ones available these days and Lundahl has the best reputation, to my knowledge.
Old 28th June 2006, 02:34 PM   #14
jane is offline jane  Norway
jane's Avatar
With ~250V at the plate and ~4V bias (2xLED) wouldn't that indicate a lot of current drawn in the 6SN7?
Life is hard - Then you die.
Old 29th June 2006, 12:46 AM   #15
alex, the Lundahl 1660S will cost you some $200 so you compare that with tube phase splitter, it will be much higher. But it's your call. For me, I haven't done one like this, so there
jane, maybe so. My mind is still thinking 417A perhaps so the paralleled 6SN7 maybe getting more than what they need.
Old 6th July 2006, 03:43 AM   #16
AJT is offline AJT  Philippines
AJT's Avatar
arnoldc,
why not push-pull it all the way? the ll1660 can be hooked up as such, a 6sn7 push-pull driver in a differential mode instead of paralleling them.
Do not despair, though they seem to be winning
now, they always fall in the end......Gandhi
Old 6th July 2006, 03:51 AM   #17
Tony, I thought of it using 5842 pairs, ala Amity.
Although I have several pairs of 6SN7, I dont like them (prejudice) in this amp. I don't know why
edit:
However, why would I limit myself
It will be driven by a preamp anyway, so I can avoid using an input transformer. What do you think?
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
looking for ultralinear push-pull project mnewport Tubes / Valves 20 25th April 2005 05:32 PM
A very simple push-pull project darkfenriz Solid State 5 6th September 2004 10:26 AM
Need Help On Push Pull Amplifier basiliou Solid State 15 11th June 2004 02:20 PM
Double push-pull versus single push-pull jraraujo Tubes / Valves 19 19th October 2002 01:23 AM
Copyright 1999-2017 diyAudio
