| diyAudio Sponsor | ||
Has anyone used the following, or similar, circuit to switch a tube heater? I'm looking for a transistor to use, but I think I might need to use a darlington pair.
Current is 600ma, hfe min 120-200. A MJE340 would almost do it with a small driver transistor with high hfe (BC547?). |
#2 |
Or maybe a power mosfet. Then there's no drive current needed.
#3 |
A FET would probably be better because you'll always have 200mV or so of Vsat across a bipolar transistor, whereas with a FET the crucial thing is the on resistance. Either way, it should work just fine.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#4 |
What's the purpose?
#5 |
A FET was the answer. I tried to reply earlier, but my post was being still being moderated.
I remembered I had a few IRLZ44 power FETs in my junk box. This tested great, so I etched the board and used the FET. The purpose is to give a PIC control of the heater. This amp (gainclone with tube preamp) is remote controlled. The PIC has a startup sequence, activated by the remote, that does the following: 1. Turn on heater. 2. 20 second delay 3. Start B+ SMPS (240 volts) 4. Start gainclone SMPS (+35 volts) 5. Increase volume to previous setting (before last shut down sequence) There is no interface on the PCB - everything is controlled from a remote. I really like this design. I'm still waiting on the digital pot IC, but everything else works great. I'm very happy with the SMPS for the tube supply. I substituted a soft recovery diode for my standard MUR160, and used some big caps with a choke in a C-L-C configuration. No switching noise, even at maximum volume. |
| how to wire 6.3VDC heater on a heater with center tap (12.6V series, 6.3V parallel)? | jarthel | Tubes / Valves | 9 | 14th April 2012 05:36 PM |
| Transistor as a Switch, is this correct? | silentblackhat | Solid State | 13 | 19th May 2009 12:05 AM |
| Can bias transistor mount on top(body) of output transistor?? | Leolabs | Solid State | 23 | 16th February 2008 12:35 AM |
| Never try to switch 450V DC at 3A with a conventional mains switch... | Eva | Power Supplies | 28 | 1st November 2006 09:24 AM |
| Using a momentary switch for main power switch? | FullThrottleRic | Parts | 9 | 25th June 2002 08:23 PM |
| Page generated in 0.08584 seconds (75.00% PHP - 25.00% MySQL) with 11 queries |
