Pro and cons high DCR filter choke
Old 19th March 2006, 04:34 PM   #1
reaction is offline reaction  Europe
reaction's Avatar
Default Pro and cons high DCR filter choke
Hello,
I have several 30H (or maybe more - my inductance meter measures up to 30H only) 65mA 1550ohm chokes from old junk field-coil speakers. They look like a round bobbin with cylinder core mounted in metal C-shaped frame (will post a picture later).
I would like to use them in several pre-amp and headphone amp designs (up to 65mA) in PSU choke input filters but I am little bit scared of their high DCR.
I read many articles re high DCR and many people said it could increase the resistance of the supply line with all negative aspects to the sound. Despite of that Duncan PSU designer reports very good results due to their high Q factor.
Could you please share your practical opinions re high DCR choke issue in SE class A designs?
Old 19th March 2006, 10:15 PM   #2
Tweeker is offline Tweeker  United States
Regulation isnt an issue with SE class A, but you need good capacitors in a high impedance supply as the supply depends more on them to draw from.
Preamps are often using straight RC sections, so higher resistance might be ok here.
Be sure your foil hat has a good low impedance ground.
Old 20th March 2006, 02:31 AM   #3
ray_moth is offline ray_moth  Indonesia
diyAudio Moderator Emeritus
ray_moth's Avatar
What Tweeker says. You don't need to be concerned about DCR of a couple of k unless the demand on the power supply is variable, e.g. a class AB1 power amp.
Old 20th March 2006, 04:42 AM   #4
lndm is offline lndm  Australia
I have not seen it explained better than Voltsecond did on his site.
http://www.siteswithstyle.com/VoltSe...C_ringing.html
http://www.siteswithstyle.com/VoltSe...LC_TANK_Q.html
These will help you design a neutral power supply. (Long but worth it).
Old 20th March 2006, 08:51 AM   #5
reaction's Avatar
Thanks for the inputs and for the useful links.
It seems to be true that high DCR chokes waste low frequency power. When the DCR increases, the Q decreases and vise versa in spite of the fact the high DCR could provide better damping and is less prone to ringing.
Old 20th March 2006, 05:29 PM   #6
R.I.P.
you could regard using a high DCR choke as a
combination of choke and resistive filtering.
As CRC filtering is a good thing for low power
class A circuits (constant current from supply),
at low/medium power it should be fine.
/sreten.
Old 20th March 2006, 09:24 PM   #7
ErikdeBest is offline ErikdeBest  Switzerland
mostly thinkerer
This made me think about the experiments made by the dutch DHTrob (www.dhtrob.com) based on steve bench's work. (Speaking about it, I believe more in the work of steve bench than that of dhtrob. Steve is more the engineer, while dhtrob is truly high-ender) Well, they both worked it out, and maybe you get some inspiration. Dhtrob says he is using it for his preamp.
The original, made by steve bench
http://members.aol.com/sbench/norchv.html
http://members.aol.com/sbench/reg5.html
DHTrob applied this for a power supply for his preamp.
http://www.dhtrob.com/projecten/voeding_vr_tubes_1.htm
the whole article is in dutch, but you can see the schematics throughout. His final schematic is shown here
http://www.dhtrob.com/projecten/afbe...g_vr_tubes.GIF
I am sure you can make something very similar with your chokes. (I would love to have some of those...I have a lot of OB2 wanting some use)
Pro and cons high DCR filter chokeHide this!Advertise here!
Choke Input Filter. G Tubes / Valves 8 11th February 2008 09:57 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 02:32 PM
Ps Filter Cap or Choke? Dr.Frankenstein Power Supplies 3 11th March 2006 08:51 AM
Filter Choke BC Parts 2 22nd September 2004 10:36 PM
Choke for Pi Filter lumanauw Solid State 48 5th February 2004 10:44 PM
