| diyAudio Sponsor | ||
#81 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#82 |
Ok, maybe I'll try 8-10mA.
These are not GTA/B just GT, max Pa 2.5W each with both fired. Will 2W and 10mA allow long life? At 10mA, a 50k Ra (what I like to use) would drop 500V. Is 20k a reasonable choice for the 6sn7? |
#83 | |
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#84 | ||
The first schema with 2 Bc549c whats it for?Just for lower current or? And the one in the middle can I use it for a 6B4G with the "Cathod resitor?"How,Is it explained somewhere? Nearly identical questions I asked here http://www.diyaudio.com/forums/showt...301#post899301
Regards Åke |
#85 |
The qualities that you want from a CCS are high output resistance and low output capacitance. For a given design, these are optimised by using the most fragile devices you can get away with. Hence, the 2 x BC549C is great when not much voltage is across the upper device and its power dissipation is low. Once the voltage goes up it tends to push the power dissipation up and that means that BC549C is no longer suitable and MJE340 is required. But a CCS using MJE340 as the upper transistor isn't quite as good as one using BC549C.
#86 |
"How is this done,do you mean to make another one just for the Led´s? "
That is what SY is seeming to suggest. My suggested approach has not introduced any noise into my preamp and is considerably simpler than a full CCS. Shoog |
#87 |
In my tweaking progress.
I removed the RC filter I had before the CCS,and what I observed is the voltage at the anodedropped to148v from 170v (6S4) and the B+ got up to 360-365v So now I have about 300v across the 6B4G But every tweak I have done has bee possitive to the sound,much clearer.So now wich one to test Shoog´s or SY´s,I dont´know.´Then this 300v to the 6B4G could it be lowered with some CCS at the Cathode"?Apriciate sugestions.
Regards Åke |
#88 | |
Now, the assumption here is that, universally, lower LED impedance is better. But that may not always be the case, as some intriguing results from rdf in another thread suggest.
#89 | ||
Regards Åke |
#90 | |
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 05:26 PM |
| 300B Cathode Feedback + Cathode Bias | korneluk | Tubes / Valves | 13 | 7th January 2009 08:07 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 01:30 AM |
| UL to triode mode conversion on cathode bias amp-different cathode resistors needed? | bigwill | Tubes / Valves | 6 | 30th December 2007 12:37 AM |
| Page generated in 0.12134 seconds (84.57% PHP - 15.43% MySQL) with 11 queries |
