| diyAudio Sponsor | ||
#41 |
As a matter of interest I decided to lash up a circuit to boost the current through the Green LEDS. I took AC of the heater and recified it with a fast soft recovery diode. I put it through some capacitance and a LM7805 and then some more capacitance. I then put it through a 330R resistor and finally the LED with a 22uf bypass cap. This gives a final current of 13mA through the LED.
The result is very good, very clear and detailed with plenty of bass. Difficult to say exactly whats what as the bias point has shifted slightly. Still it works. All the previous softening and smudging has gone. Got a bit of hum and don't need the extra gain so don't know if I will keep it, but I think it sounds better than a plain unbypassed resistor. Shoog |
#42 |
So when I look for the right Led,if I want 1,5 v at the catod and 15mA current I look at the Led´s Forward current/volt and find one that crosses at 1,5v/15mA? Is that right?
Seccond question-Does anyone have a schema for a CCS for the anode or can make one?
#43 |
Take a look at the CCS I used in the thread "SY gets jiggy" for a good example of an inexpensive plate CCS that works very well.
The LED "curves" take off pretty sharply at a particular voltage rather than being a smooth curve. So look for a color with a Vf near the bias point you want, which will generally be specified at 10mA; there won't be a lot of difference between 10 and 15mA.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#44 |
Hi Shoog, have you tried bypassing the LED with a cap yet? In my measurements the green LED benefited most from it, dropping all harmonics below the noise floor of the sound card and besting both the red and the yellow. Curious whether it makes an audible difference for you. On the bench it took at least 25uF to reach maximum benefit and 6.8uF made little difference. The bypass occurs in the midrange for these values so theoretically it possibly alters the stage frequency response to some degree. How much depends on the degree of degeneration caused by the LED I suppose.
Blame the Manichaeists |
#45 |
This might help when choosing LEDs for a specific voltage and current...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#46 |
And this illustrates how sharply LEDs take off. It's the same red LED in all three attachments.
#47 |
"Hi Shoog, have you tried bypassing the LED with a cap yet? In my measurements the green LED benefited most from it, dropping all harmonics below the noise floor of the sound card and besting both the red and the yellow. Curious whether it makes an audible difference for you. On the bench it took at least 25uF to reach maximum benefit and 6.8uF made little difference. The bypass occurs in the midrange for these values so theoretically it possibly alters the stage frequency response to some degree. How much depends on the degree of degeneration caused by the LED I suppose."
I did bypass the Green LEDs with 22uf, but this was more to do with generating a stable 9mA current boost than bypassing audably. Can't say if it has effected the sound as I have nothing to compare it with really. I have been sufficiently impressed with the boosted current version that I have kept it in my preamp. Overall there is a significant amount more detail across the whole audio range compared to an unbiased cathode resistor. Got rid of all residual hum and shifted the bias points to compare more with the original version. Well worth the effort. Shoog |
#48 |
Can somebody please explain this to me.
Last night when playing music, I observed that both the orange LEDs are flashing at a regular interval. After a while, the flashing stoped. I turned my record to the other side, played it and the flashing starts again. When I investigated, the record that I'm playing has a horizontal warp at one point. When the cart hits that point, it must be banging left and right on the vinyl groove What the?? Hey ryssen, tubelab has a nice schema of the 10M4 IXYS CCS as an alternative to that of SY. They're cheap and I'll be ordering a couple from RS Components. Pete Millet has also experimented with them, with positive outcome. |
#49 |
The brightness change is an indication that you're clipping that stage.
Another nice benefit of using a LED, a built-in distortion monitor!
#50 | |
I was about to put together a test setup to make this curve when you posted this. For anyone that wants to look at these curves themselves with different diodes, there's a really simple setup. |
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 06:26 PM |
| 300B Cathode Feedback + Cathode Bias | korneluk | Tubes / Valves | 13 | 7th January 2009 09:07 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 02:30 AM |
| UL to triode mode conversion on cathode bias amp-different cathode resistors needed? | bigwill | Tubes / Valves | 6 | 30th December 2007 01:37 AM |
| Page generated in 0.13504 seconds (77.82% PHP - 22.18% MySQL) with 11 queries |
