diyAudio Sponsor
Old 18th March 2006, 06:21 PM   #21
astouffer's Avatar
LEDs have a bad reputation for bias use. I hear a lot of people say diodes are non linear etc etc but its mostly rumor. I wired up a single triode gain stage with an old red LED for around 15ma bias and measured excellent results. No visible distortion to 200khz, the limit of the signal generator. Its cheap to implement and worth a listen.
Old 19th March 2006, 12:44 AM   #22
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
That's precisely the point of my experiment. I've read mixed good/bad reactions on LED use for bias with no supporting explanation. That's why DIY Audio is also different, we have people like SY
I'm enjoying my mod right now and I will modify all my projects that use 417A with cathode resistor bias.
Old 19th March 2006, 12:39 PM   #23
Shoog's Avatar
Another piece of DIY guru ******** bits the dust. What shall we try next ??
Shoog
Old 19th March 2006, 06:04 PM   #24
rdf is online now rdf  Canada
rdf's Avatar
Well, maybe. I did a round of bench testing last night on a variety of LEDs - red, green and yellow. Each was biased at 10 ma with an IXYS solid state constant current source and a 800 Hz, 1 Vp-p signal was fed into a 1000 ohm resistor connected at the LED-CCS junction. This is roughly equivalent to 1 ma p-p injected into the LED. An FFT of the junction voltage revealed all LEDs show a second harmonic roughly 50 dB below the residual fundamental (already ~55 dB down itself in this circuit.) An eight ohm resistor - that value being equivalent to the AC impedance of the best LED - showed no 2nd harmonic above the noise floor of the test jig. The best LED was an unmarked, small red LED, the worst an identical looking Mode model! Raising the bias current from 10 ma to 15 ma took another 6-8 dB off the second harmonic and (wasn't paying a lot of attention to this part) 1-3 dB off the fundamental for all those tested.
Obvious in hindsight I guess. Since the LED has an AC impedance greater than zero some AC signal will always appear across it, and AC signals across diodes get rectified. Also an LED's impedance is a function of bias current and type, nothing others haven't already noted. What it does suggest though is that LEDs work best in specific applications. The 6C45 driver of my EL84 amp for example is relatively high DC bias (12 ma), loaded by a constant current source and drives a 920 kohm grid resistor. These conditions minimize the AC current through the diode and might be the reason it works so well for me.
In other words these results suggest to me that dropping a LED in place of a cathode resisistor without regard to colour, DC bias and AC current could well result in 'funnies'. Personally I wouldn't consider, say, a blue LED for a mildly biased interstage-loaded tube without a whole lot of testing. From a bit of Googling it appears in terms of impedance that infrared LEDs show the highest promise if the low voltage drop suits your circuit's needs. They're available in high power versions good for 100 ma and the impedance curves appear the most linear and steep in the 10-20 ma range. No 24 hour LED stores open Sundays around here so that's an experiment for another day.
Blame the Manichaeists
Old 19th March 2006, 06:19 PM   #25
SY's Avatar
That -50 dB number is better than I can measure, so it may well be true. I assume you saw no higher order harmonics?
Your observation about not knowing what it will be until tested is certainly true. And your observation that the biasing current MUST be thought through is screamingly true. I would never use a LED at 2mA.
The nice thing about maximizing plate load is that you minimize the current swing. One would expect that the 2HD content would scale roughly with current swing, so using high values of plate load (CCS if possible) is good engineering practice.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 19th March 2006, 07:56 PM   #26
Dave Cigna's Avatar
Thank you SY for reminding us that current swing is important. It would seem to me that using an LED to bias an input tube running a couple of mA, then swamping that with a couple 10's of mA to bring the resistance into a linear range could work really well. On the other hand, a driver biased at 20mA swinging 10mA might introduce quite a bit of 2nd HD.
Old 19th March 2006, 09:11 PM   #27
rdf's Avatar
More tests are required, but it's just too sunny at the moment. Third harmonics did appear with enough generator signal. The circuit is being fed from the headphone output of an M-Audio Aduiphile USB. A volt P-P into 1000 ohms is about its maximum happy output, at higher levels the distortion components of the USB headphone amp begin to peek above the noise at the jig's input. I suspect a complete monotonic sequence of harmonics is buried in the mud.
One aspect of what I found doesn't make sense, at least to me, and also requires testing with different LEDs and frequencies before making too much of it. Bypass caps seem to affect the harmonics to a greater degree than simple voltage divider rules would imply. Values below 10 uF had almost no visual effect - using a ~8 ohm red LED - on fundamental or harmonic. Between 20 uF and 30 uF the fundamental drops a couple of dB, the second harmonic more than 15 dB. Perhaps an issue with the test rig, I don't know and am not sure how to appoach it. When the sun goes does that is...
Old 19th March 2006, 09:21 PM   #28
SY's Avatar
Heh, I'm 5000 miles from home at the moment, so I've got a better excuse for not running out to my garage/lab to try a few experiments. Here's how my test setup worked: I set up a 6SN7 with the test LED in the cathode and a 4.7k resistor on the plate. Using a variable supply, I adjusted for the desired standing current (10mA in my case). Then I applied enough signal to get 4.7V peak across the resistor. I put a spectrum analyzer across the LED and measured away.
The setup could certainly be improved by interposing a low noise opamp with a hunk of gain between the LED and the spectrum analyzer, since the fundamental is low enough that the analyzer's sensitivity becomes the limiting factor.
Dave, swinging 10mA with a 20mA standing current, the bias scheme will be the least of your worries as regards contribution to distortion!
Old 19th March 2006, 11:36 PM   #29
I don't want to throw any assumption but here goes Maybe those who said LEDs suck didn't care for color, or current load, and the brand of coffee.
I've been reading the LED posts here and never moved my *** until something cought me- 10mA Since that is the current I'm running my 417A on, that just gave me a hard kick in the butt that led me to doing this.
And I must say it pays off. Just like most of the forumers here, I take everything with a bucket of salt. But hey, when you see/hear it for yourself, it's priceless
Please keep the test information flowing, I learn a lot from it and I'm sure others will.
Old 20th March 2006, 05:26 AM   #30
rdf's Avatar
That's quite the coincidence, both our setups were effectively injecting ~ 1 ma into the LED. Your approach was more real-world valid. Measuring in-circuit is more apt to catch things I'ld never guess beforehand. The jig's a convenient start because it eliminates noise and harmonics potentially generated elsewhere in the circuit and gives me a better grasp on the raw device.
That said, PDF attached for your in-flight reading pleasure. The suppression abilities of three generic LEDs were compared with two different injection frequencies under three bypass conditions: none, 6.8uF and 33uF. Same as last time the bias level was 10 ma DC. The first comparison of interest is between the 'no bypass' columns. At 500 Hz and 5000 Hz the suppression of fundamental F1 and second harmonic F2 are identical within the limits of measurement repeatability. Exactly as you'ld expect and as I recall what you found as well. Next thing, unbypassed the red LED is, no surprise, the clear performance winner. It suppresses F1 and F2 the most.
The bypasses complicate the picture a great deal. I would expect on a straight impedance point of view that, since the impedance of the bypass at F2 is 1/2 its value at F1, F2 would be suppressed in the range of 6 dB more than F1 for any given value of capacitance. Turns out this only held approximtely true for the red LED and 6.8uF combination. For all others F2 was consistently suppressed far more than the change in F1 + 6 dB. With the green LED and 33uF bypass combined the difference was more than 25 dB! Also surprising was that with the 33uF bypass the green LED was arguable the best performer. The -125 reading shown in the sheet was for calculation convenience only, in reality no hint of F2 was visible above the noise floor. I can see the degree of reduction being higher for a LED with greater internal impedance but can't see how it beats one with less under the same conditions.
More head scratchers
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 06:26 PM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 09:07 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 02:30 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 01:37 AM
Page generated in 0.13752 seconds (85.05% PHP - 14.95% MySQL) with 11 queries
