| diyAudio Sponsor | ||
#111 |
Hi Indm, I'm running EL34 PP in AB1 so I must be in the same predicament.
Sigh... maybe I'll be lazy and just use a LM317 shared by both cathodes |
#112 |
EL34 might be pushing things because of the high bias voltage requirements, but it could be done. If you've got 34V requirement, that's 20 red LEDs per string. You'll need 10 strings to handle the current. Let's see, for a 6 ohm per-LED impedance (you can do better, but it takes some searching), that's 120 ohms per string. 10 in parallel gets you to 12 ohms impedance, a bit higher than you might want, but not unreasonable (Dynaco used a 15.6 ohm resistor in that spot). So, it's possible, but with 200 LEDs per channel, perhaps slightly over the top.
Or maybe not so over-the-top. At surplus, I've been getting my LEDs-of-choice for a little under 5 cents. So that's $10 per channel for a stable and reliable bias supply. Hmmmm......
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#113 | |
#114 |
Well, I've had this ST-70 sitting in the garage that needs a rebuild. You've got me tempted.
#115 |
Maybe when I get the time to do the individual testing and compiled 400
Right now, there's no looking back for me. I changed my WE396A preamp to use LED on the cathode, and while it sounded good already with RC on the cathode, the LED puts it in a different league. I substituted the 2C51 and it sounded so good. When I get back my 12B4, maybe I'll attempt the first step. I'll change its LM317 cathode current source with LEDs and check the difference. If I hear it then, I know what's the next step |
#116 | |
Brian |
#117 |
This from the guy who built a kilowatt transmitter to run a pair of Quads.
edit: Approacing? I'd kill to get gas for $3. Around here, $3.50 is about as cheap as it gets.
#118 |
If a US gallon is 3.785 litres, I paid $5.68AU/g this morning.
#119 | |
Brian |
#120 |
I paid PhP500 for 12.5 liters of 95 octane gasoline this morning. I'm glad I have a small CR-V
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 06:26 PM |
| 300B Cathode Feedback + Cathode Bias | korneluk | Tubes / Valves | 13 | 7th January 2009 09:07 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 02:30 AM |
| UL to triode mode conversion on cathode bias amp-different cathode resistors needed? | bigwill | Tubes / Valves | 6 | 30th December 2007 01:37 AM |
| Page generated in 0.10626 seconds (77.20% PHP - 22.80% MySQL) with 11 queries |
