diyAudio Sponsor
Old 9th May 2006, 05:03 PM   #101
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Okay,I go back to where it worked,the original CCS 300v/15mA,worked fine.My idea besides CCS for the Led´s(Do you have a suggested dessign-NPN-?)was direct coupling,that´s why the higher voltage 495v.
Will an RC filter be enough to bring the votage down to safe level(300v)or shall I use a SS regulator?
4.
Regards Åke
Old 9th May 2006, 11:49 PM   #102
lndm is offline lndm  Australia
Do you have a circuit simulator? I have created so much smoke on my computer that by rights I shouldn't be able to read the screen anymore.
Old 10th May 2006, 01:14 AM   #103
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Originally posted by Ryssen
My idea besides CCS for the LEDs, (do you have a suggested design - NPN?) was direct coupling, that´s why the higher voltage 495V.
Will an RC filter be enough to bring the votage down to safe level (300V) or shall I use a SS regulator?
The NPN design is with the others in the earlier thread about CCS PCBs. A correctly-designed RC filter will be adequate to bring the voltage down to <300V (I would suggest 250V).
I repeat that you need to learn more about theory before attempting to modify designs. You can learn about "boring" theory or you can live with "exciting" explosions/smoke and destruction of expensive components. The choice is entirely yours...
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 10th May 2006, 08:14 AM   #104
Ryssen's Avatar
Yes I know about the NPN CCS, I will try to implant it into this project of mine.
Yes you are right,I will read more more on the subjects,maybe I´m just in a hurry to get it done. ....
Suggest one.
Regards Åke
Old 10th May 2006, 08:25 AM   #105
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Simulators -
LT SPice from Switchcad
Simetrix from Cadena
and a couple more...
Old 10th May 2006, 08:36 AM   #106
CircuitMaker.
Version 6 student edition is free (limited to 50 components at once) if it's still available. I use cm2000.
Old 10th May 2006, 05:03 PM   #107
Ryssen's Avatar
Ehmm...little OT,trying LT spice,I can´t edit the Led Diode properties-gray field,how.And how do I get the symbol of a triod?I´ll bet it is an easy answer..
Regards Åke
Old 11th May 2006, 12:42 AM   #108
hi ryssen,
please visit duncan amps website for the models of the different devices. the site also has instructions for using a tube model.
When you click on Component from the toolbar, you selected a diode and it was labelled D1 D.
Now, insert the model entry for the diode, example 1N4004:
.MODEL D1N4004 D(IS=2.55E-9 RS=0.042 N=1.75 TT=5.76E-6 CJO=1.85E-11
+ VJ=0.75 M=0.333 BV=400 IBV=3.95E-5 )
Copy this text, press S on LT Spice to insert a Spice direcftive. Paste the text.
Then Right Click on the D label of your diode and type D1N4004 into the text box.
That's my OT answer
Old 11th May 2006, 08:03 AM   #109
Back to topic...
Sy, you think I can make a "red light district" PP EL34? I plan to change the cathode resistor of my EL34 PP amp with a bunch of red LEDs 35V / 1.5V = 24 red LEDs?
Old 11th May 2006, 08:47 AM   #110
I thought of doing this. I baulked when I figured that if I wanted 10mA per LED, for 100mA I would need 10 strings of diodes (I don't have SY's experience here though).
Changing grid leak bias preamp to cathode bias bereanbill Tubes / Valves 8 28th March 2009 06:26 PM
300B Cathode Feedback + Cathode Bias korneluk Tubes / Valves 13 7th January 2009 09:07 PM
Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 awedio Tubes / Valves 2 19th April 2008 02:30 AM
UL to triode mode conversion on cathode bias amp-different cathode resistors needed? bigwill Tubes / Valves 6 30th December 2007 01:37 AM
Page generated in 0.09435 seconds (85.86% PHP - 14.14% MySQL) with 11 queries
