Higher value oil capacitors? - Page 2 - diyAudio
Old 16th March 2006, 02:39 AM   #11
rdf is offline rdf  Canada
rdf's Avatar
Hi Sherman. Midori's site gives the impression just the 100 uF value cap is the ASC Shizuki model from Japan. I have both American (40uF and 60 uF, bought from Allied Electric if I recall) and Japanese ASC caps. The first have magnetic terminals, the second don't. Do you know if the 40 uF caps you bought from Midori are magnetic? Thx in advance.
Ears aren't microphones.
Old 16th March 2006, 03:47 AM   #12
kevinkr's Avatar
The Midori Meadows ASC 100uF caps are the japanese made Shizuki with non magnetic construction - aluminum cans and copper terminals. I bought 4 less than a month ago.. Nice caps. I am not sure that any of the others currently available there have copper terminals, but I believe it is the case that all X386S series caps are non magnetic construction and some/most do also have copper terminals.
Sharon orders more custom made caps from Japan from time to time and I believe that there are some interesting ones arriving shortly.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th March 2006, 04:11 AM   #13
Thanks guys!
What does the "motor run" refer to?
And (not having heard them) what is their sonic signature vs better electrolytics ~
More or less detail? smoother? Faster? Other?
Cheers
Old 16th March 2006, 04:33 AM   #14
Kevin,
Are the X386S caps the ones that are good to 600V DC?
Thanks,
Looney
Old 16th March 2006, 07:15 AM   #15
rdf's Avatar
Hi Kevin. The 100 uF caps I bought from Midori are the same as yours. However that value is the only cap she specifically calls 'Shizuki'. Her 55 uF ASC is labelled 'made in USA' and doesn't mention Shizuki. I know for certain the 40 uF and 60 uF American-made ASC X386S caps I bought from Allied Electric use steel terminals.
A good heads up, thanks!
Old 18th March 2006, 05:57 PM   #16
kevinkr's Avatar
Hi LooneyTunes,
It depends a lot on the internal construction, I have noted some capacitors with relatively low AC ratings which have much higher dc ratings than the rms to pk volts rating would imply, and others where this is clearly not the case. I think these voltage ratings relate more to corona inception voltage than the dielectric strength of the film and this is construction related.
I guess to make a long story short, I wouldn't operate these particular capacitors at anything higher than 500V as they have a 330VAC rating, and I have not found a specific reference to a safe max voltage on the ASC site for these caps, although there are some general guidelines.
Old 18th March 2006, 07:29 PM   #17
Sherman is offline Sherman  United States
I don't actually know if the terminals are magnetic or not. I suspect they probably are to at least some degree as they appear to be steel.
--Sherman
Old 18th March 2006, 07:35 PM   #18
Originally posted by rick57
Thanks guys!
Cheers
There are two types of caps commonly used with AC induction motors such as those in furnace blowers, pool filters etc., motor "start" and motor "run".
Motor start caps give a "boost" to the power at the time the motor begins operation to get is moving. They aren't designed for continuous use. Motor run caps are designed for continuous use and are the ones you want for amp use.
I have a hard time describing sound in words but I suppose I would say the oil-filled motor runs sound less "grainy" than inexpensive electrolytics. More costly 'lytics have a sound closer to the motor runs.
--Sherman
Old 19th March 2006, 06:46 AM   #19
Thanks Kevin,
I was hoping that these ASCs would stretch to 600V. Oh well... A minor disappointment is better than fireworks, although not nearly as "exciting".
Looney
Old 19th March 2006, 09:36 PM   #20
protos is offline protos  Greece
protos's Avatar
The midori ones are 370 VAC rated so they are maximum 520VDC.However there may be some who would stretch them to 600 VDC. I have used these in my amp up to 530 VDC on a continuous basis and on one occasion they were tried as high as 600 V but briefly.Better play safe with 600VDC and get the higher V rated asc caps.
what is the difference between silver mica capacitors and ceramic capacitors ?? prorms Solid State 1 6th May 2008 01:38 PM
Is it true that the higher the BL of a subwoofer, the higher its lowest playable... 454Casull Subwoofers 16 19th March 2004 05:28 PM
Flying higher and higher with the Doede Dac Lucas_G Digital Source 139 27th February 2004 07:40 AM
Super-power amps - higher current better than higher voltage Circlotron Solid State 34 28th June 2002 05:01 AM
differences between computer grade capacitors and small can capacitors LBHajdu Pass Labs 0 22nd February 2002 02:29 AM
Copyright 1999-2017 diyAudio
