Old 13th November 2002, 09:14 PM   #21
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Default I admit nothing...
Except that I found the 6550 and excellent cathode follower to drive SV573-3's into A2; got 25W easily.
Now find me a double triode that will swing 400v P-P @ 15mA as a cathode follower, and stay linear.
No, no, no, I ended up with a massive interstage transformer driving my 845 amp, but the bias supply to the secondary "cold end" still needs to be "stiff", otherwise it's the same problem when the output valve's G/K goes into "rectifier mode".
The poor lovelys now peak at +75v on the grids.
Even with tone, there is no grid deformation, and no characteristic change, short (or long term) as yet.
So I don't think music is a problem at all.
But a big good transformer is expensive, and Joel is on a budget.
Damn, that's my warranty gone; jac please close your eyes!
I don't think valve noise is a big issue with driver stages is it?
Here's to grid current.........
Old 13th November 2002, 09:45 PM   #22
diyAudio Senior Member
fdegrove's Avatar
Default CF
I haven't looked into this really but I suppose the big triodes could swing it.(pun intended)
The thing is that it would be hard to justify their use there.
These beam tetrodes aren't that expensive and if they do the job,why not?
Agreed,regulate it or clamp it with a glow discharge tube.
He'll find a "used" one.
No,if I can avoid it I will.
Remember those microdetails....
The bottle is open.
Frank
Old 14th November 2002, 12:34 AM   #23
Circlotron's Avatar
Default Source follower instead
I always thought it would be an interesting experiment to use a source follower when driving a stage that drew grid current on the peaks. The cct would be dead simple and plenty of HV fets available. The lower the capacitance the better. Should have a stiffer output than any reasonable size tube. That's if a fet suits you of course.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 16th November 2002, 06:55 PM   #24
dhaen's Avatar
Honestly, this isn't a cruisade but:
What would be the gate capacitance of a suitable device?
Direct-coupled cathode/source follower driver in PP? ray_moth Tubes / Valves 83 17th July 2008 02:53 AM
Cathode follower driver croccodillo Tubes / Valves 13 30th September 2006 04:47 PM
Driver stage for power follower amirmk Chip Amps 1 6th August 2005 02:04 AM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
Cathode follower Class A output stage? Circlotron Tubes / Valves 14 15th May 2003 11:11 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
