diyAudio Sponsor
Old 12th March 2006, 07:32 AM   #1
john is offline john  Philippines
john's Avatar
Default Tubes for Lumley ST40 power amplifier?
A friend is asking me to restore a tubeless Lumley ST40 tube power amplifier.
Anybody out there might own one ST40 who knows all the tube compliments?
Your help is kindly appreciated,
John
Old 12th March 2006, 11:16 AM   #2
I did a search and turned up nothing. There are others that may have more luck.
If nothing is found I would suggest drawing up the schematic and posting it for all to view. This might not be a bad idea anyway.
Old 13th March 2006, 12:48 AM   #3
john's Avatar
Default Tubes for Lumley ST-40 power amplifier?
Thank you for your effort Sir.
I will try to draw the schematic diagram.
Old 13th March 2006, 05:15 AM   #4
john's Avatar
I am still needing information on the types of input and phase splitter tubes. They can either be 12AX7, 12AU7 or 12AT7. These twin triodes I can try them out, But the Tube which is used as a screen regulator is the information I needed badly.
The ST-40 uses 4 EL34 tubes on the output stage.
The Tube (octal based) at the back of the Toroidal Power tranny is data I need. I assume this could be employed as a screen regulator. It got 6.3 volts filament at pins 2 and 7, The Grid (Pin 5) measures 307 VDC and pins 3 and 4 measures ( Plate and Screen) 480 VDC. Is this tube could be EL34 or 6550 or 6L6 ?
Your help is highly appreciated!
Thank You,
John
Old 13th March 2006, 02:15 PM   #5
Alain Dupont's Avatar
john,
Seen something about the tubes of a ST70 ; search on yahoo for Lumley ST70 amplifier
ECC ... don't remember.
Alain.
Old 14th March 2006, 01:08 AM   #6
john's Avatar
Thanks Alain,
The ST70 uses 6650 and the ST40 uses EL34. The input and phase splitters are ECC82 and ECC83.
I am still uncertain about the octal based tube employed as a screen regulator located at the back of the toroidal power tranny. It could be an EL34 or a 6550?
Help anyone!
John
Old 14th March 2006, 01:40 AM   #7
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
john, the designer is Ben Carter. His email is b(dot)carter(at)homecall.co.uk
Old 14th March 2006, 02:42 AM   #8
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
Default Re: Tubes for Lumley ST40 power amplifier
Originally posted by john
Thanks Alain,
Help anyone!
John
hi john,
perhaps you mean the ST70 uses EL34's while the ST40 uses 6550 which can use screen regulators, well, another 6550 for screen regulator will not be a bad idea, but a 6as7/6080 will be better, error amps used 9pin miniatures? plus a discharge type vr regulators right?
Old 14th March 2006, 12:14 PM   #9
john's Avatar
Thank you for the information Arnold!
Hi Tony,
Lumley ST70 uses 6550 as an output tubes, while the ST40 uses EL34 as output tubes. It's puzzling for me since what tube should I use to the another octal socket which is employed as a screen regulator, since the Bplus is solidstate rectified. I am considering of plugging in on the either 6550 or EL34 if I can't source the schematic diagram or any information on the tubes that were employed on this rare amplifier.
Based on the voltages I have given above, what tube would fit the as a screen regulator?
John
Old 15th March 2006, 02:07 AM   #10
Tony's Avatar
El34 is my bet in this case, at plate of 480 and grid of 305, your output could be around 340~350 which is fine.
Ray Lumley m100 schematic needed antibill Tubes / Valves 0 18th March 2009 12:19 PM
High-power amplifier using transmitting tubes Michael Koster Tubes / Valves 39 14th January 2009 11:48 PM
Lumley M250 Woes HuggyBear Tubes / Valves 4 31st March 2003 10:04 PM
Lumley reference AuroraB Tubes / Valves 2 31st March 2003 08:30 AM
Assemblage ST40 Amp kit parts transducer Swap Meet 1 4th October 2002 05:10 PM
Page generated in 0.12064 seconds (79.89% PHP - 20.11% MySQL) with 10 queries
