diyAudio Sponsor
Old 10th March 2006, 01:20 PM   #1
gary f is offline gary f  Canada
gary f's Avatar
Default Problem: Really Bright glowing 6CA7
Yesterday, one of my 6CA7 tube in my amplifier started to glow really bright while I was listening to music. It happened after maybe 1 hour of listening, the gray cathode-plate assembly became incandescent with a red-yellow light, as if the heather was too hot. The amplifier was still working OK at that time and music seemed fine. I turned off the amplifier, and waited a bit for tubes too cool down. I swapped tubes, and turned the amplifier On again, and everything was OK. I listened to some music for at least one hour, and everything was normal. The amp is a Dynaco ST-70 serie 2, from 1990.
So right now, I don't know if it is tube related or a problem with the amp.
-Anybody seen something like this?
-I read the archives, and someone mentionned maybe a bad coupling cap problem. Is this possible? And why does it seems intermittent. It is surely related with heat...
Thanks for any input.
F
Old 10th March 2006, 01:39 PM   #2
SY's Avatar
It could be an intermittent coupling cap, but with that amp, if you still have the original tube sockets, the problem may well lie there. I'd replace all the output tube sockets (it's a pain in the ***, but Dyna used some really cheap hardware). If the coupling caps are original, you probably want to replace them, too, just to be sure.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 10th March 2006, 02:08 PM   #3
gary f's Avatar
SY: How a socket problem could produce excessive heating of the tube and glow?
If it is a socket problem, I can change sockets and caps. I will try to reproduce the problem to be sure
F
Old 10th March 2006, 03:11 PM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
The other night while playing around, I forgot to put back the heatsink on the regulator to my heater... after a while my wife called me, because the music was starting to go softer... on looking a the valve it was brightly glowing, as the heater was getting something like 10V because the regulator had a thermal shutdown of some sort.....
Old 10th March 2006, 05:01 PM   #5
testlab is offline testlab  United States
testlab's Avatar
You have lost bias or lost a tube my friend. The other possibility is mentioned above, a bad coupling cap after the phase inverter.
It's not whether you win or lose, it's how you lay the blame.
Old 10th March 2006, 08:19 PM   #6
richwalters's Avatar
Some power tubes used in fixed bias mode go through the red hot to melt down phase at end of life. It can happen quite quickly and dramatically.
Check Pin 5 (g1) octal skt for continuity i.e contact condition,and neg volts if fixed bias is used. Check the soldering in the valve pins....(once I had a 6550B with a suspect duff heater, found to be poor soldering in tube pins)
A fuse in the output transformer ct will protect tube and tranny and if it blows will give the hint something's wrong. The fuse has no sonic effect.
Where's best place for ST2 schematic ?
richj
Old 10th March 2006, 08:29 PM   #7
SY's Avatar
Gary, if the socket pin corresponding to the tube's control grid loosens, corrodes, or otherwise has intermittent contact, the tube will lose bias and run away. That produces a nice light show...
While you're under the hood, check the cathode resistor (the 15.6 ohm) to see if it is cracked or changed value. Tube runaway stresses that part and I've seen more than one go blooey shortly after an over-current incident.
Old 11th March 2006, 10:15 PM   #8
gary f's Avatar
Default Schematic
Thanks everyone
The amp seems fine since yesterday. It may well be a bad contact. I had problems with these sockets. I will check resistance value and caps anyway. If the problem arise again, I will change sockets.
Here is the schematic. This is Dynaco Serie II by sound valves, redesigned in early 90's
F
EDIT: hum, the file is way too large at 2,4 MB. Email me if you need the schematic
Old 11th March 2006, 11:06 PM   #9
testlab's Avatar
I used to work with the engineer who re-designed that piece. He was really gratified by the review it got in The Absolute Sound.
Old 12th March 2006, 04:30 PM   #10
gary f's Avatar
Do you have a copy or link of the article?
This amplifier is very good. I like the sound very much, although I don't have much experience with expensive amplifiers so I can't compare with other products.
I have a custom chromed version, and the look is very very nice.
Thanks for all the information everyone!
7591 is glowing RED dognut Tubes / Valves 2 1st March 2009 06:16 PM
EL84s glowing red twalker Tubes / Valves 7 7th December 2006 02:50 AM
Vox tubes glowing red hot Franconio Tubes / Valves 10 4th April 2006 01:13 PM
tube is flashing and glowing very bright! pho_boi Tubes / Valves 8 9th February 2006 09:16 PM
7199 glowing purple? GLF Tubes / Valves 10 17th February 2003 11:08 PM
Page generated in 0.11571 seconds (76.02% PHP - 23.98% MySQL) with 11 queries
