| diyAudio Sponsor | ||
#1 | |
Hi everybody,
Quite a while ago I was trying to design a new SET amplifier around a couple of 6C33Cs I've got from a Russian friend. I was wandering about a cathode follower output stage, and was facing the problem of designing a proper driver without resorting to an (expensive & bulky) interstage transformer... but eventually I ended up with another, rather "strange" idea. It was not a cathode follower proper anymore. But it was something new (at least, I've never seen it done before by anyone) and I have been quite curious to try it out. You can see it sketched in the attached picture. Without any value and component information, at a first glance it may look a lot like something well known, namely the SRPP or "Totem Pole" circuit ( hence the "fancy" name I've given to it ).But indeed it is NOT an SRPP. It may still be called a "Totem Pole", but it's not one of the usual kind. While topologically it is the same, here the two tubes are completely different from each other, as are their currents. The "lower" tube is actually just a driver, directly coupled to the output tube by means of the "totem pole" connection. Most of the current of the output tube goes down the OPT while only a small fraction of it goes down through the driver. The resistor in the middle is high enough to provide by itself a decent load for the driver, which is thus somewhat "shielded" from load variations. I have run some simulations and found that -while obviously having both advantages and drawbacks-, it could indeed be quite interesting. Thus I went on and built a prototype using the 6C33 as power tube. In spite of the "random" (mostly cheap) components used and the test construction, listening room "test" results have been rather good since the very first prototype. Currently I'm still experimenting with various drivers, trying to find the best match. I have also run a lot more simulations, with various drivers and output tubes, and have found some rather interesting "pairs". One is PCL82/6BM8 as pre+driver and EL34 as power output. More on this later. One of the interesting thing about this circuit is that it can be used as an alternative way for implementing the "Complementary Inverse Distortion Cancellation" suggested by John Broskie on www.tubecad.com (for that, you should use the same kind of tubes for both the driver and the output, with more than one tube in parallel for output, taking care to carefully match voltage and currents on output and driver tubes... it's kind of a mess, but can be done). Needless to say, small & cheap tubes such as 6BQ5 / EL84 or the Russian 6C19 (low rp!) should be best for this use. The nice thing about using the "PowerTotem" rather the the original configuration proposed on TCJ is that you are not completely wasting the current from the driver. And It also imply that you are subtracting a substantial fraction of DC current from the OPT, which will surely make it happier. (a drawback - but someone may say it's rather an advantage - is that you loose the 100% local NFB of the true follower output stage).More to come... have fun!
#2 |
The fact that the tubes are different really does not make it any less of a SRPP...
#3 |
tarmac ripper
Was John Broskie saying that SRPP are not that good in driving capacitive and lower loads (as a speaker can be)?
Ciao Gianluca PS I am currently running a mixed SRPP with an EF184 over a 6H30 (in the driver stage). |
#4 |
Hi Paolo,
call it as you like, but you will have most serious problems to get any substantial output power out of it. The current bypass through the OPT is nothing else than a CF loaded inductively, thus the same restrictions for drive requirements do apply. I wonder how you will get the needed drive voltage swing. Efficiency must be extremely bad. Would be nice you could supply some real world measurements. Tom
If in doubt, just measure. |
#5 | |
This is interesting, if this is true, can we redesign our SRPP for 8 ohms an do away with the OPT? |
#6 |
I have seen designs for SRPP OTL amplifiers using a quartet or even septet of 6C33 in MJ, they were hideously inefficient, and produced very little output power. The amplifier design in question used about 1KW to produce 40W out.. I have heard one design which was pretty anemic sounding despite the horrendous power consumption.
IMHO designing something like this to sound good and work well is a bigger task by far than a good comparably powerful amplifier with a transformer. Of course if you like big challenges it might be worthwhile.. Incidentally you can get 15Wrms out with a single 6C33 and a 600 ohm transformer - not a bad trade off. It is not hard to build a really good opt with a winding ratio of 8.7:1 (600 ohms to 8 ohms)
www.kta-hifi.net |
#7 | ||
In my circuit the "upper" (output) tube is working (more or less) as a CF loaded by the OPT, while the "lower" (driver) tube is working as a grounded cathode stage... the "trick" being using the output stage as (sort of) an active load for its own driver. At least, this is how I have interpreted it. Please correct me if I'm wrong!
#8 | |||
Actually, I guess he was (also?) arguing about the use of the SRPP circuit as a line preamplifier stage (as many indeed do, and IMHO usually with good results). But, as said, I believe that what I've done - am doing is quite different. Quote:
Wow, that would be cool! ![]() I'd be very interested about it... how is it behaving? can you post more details?
#9 | ||||
Hi Tom,
BTW, I must say that having a small distorsion on the driver is NOT desired! This is because the distorsion from the driver can be conveniently used to reduce the overall distorsion on the output. ![]() The real problem is finding the "right" tube, i.e. the one that fit best to give the best overall performances. I've tryed (most in simulations, some on the prototype) countless different tubes and operating points... a very few fits nicely, and I'm still seeking for the "right" one. (more on this as soon as I'll post the complete schematic (and results) for the current prototype). Quote:
BTW I'm still looking for a "better" (best suited) driver... I do belive that it is possible to do even better! And /in simulations/ I got 10W out of a triode-strapped EL34 driven by a (triode-strapped) PCL82, which seems to be a nice fit for that... I'll post this too... but again next week, I don't have them here now. Quote:
#10 |
tarmac ripper
Unimax,
I can't remember values now ... but the driver I was talking about is nothing new nor complex. A plain vanilla SRPP but with two different tubes and using a penthode as upper valve: half 6H30 biased with RC/LED (switching back and forth) loaded with an EF184. The screen is bypassed to EF184 cathode via a 100uF e-cap. 100R grid-stoppers. Tubes run at 15mA (or something like that). Signal out is taken from the lower plate (did J. Bronskie suggested it somehow?) and fed into an interstage parafeed tranny via a paper/oil cap. I tried a regular SRPP (6H30) and later I trew in the EF184 a la Kimmel but no coupling cap. I liked it. After a while I took the output from the lower 6H30 plate instead of the upper penthode cathode. Better. Much better. Deeper, faster bass and more details. This is not a power stage and 6H30 is looking into a high impedence load (the tranny // EF184). EF184 is just a sort of CCS there. I saw somewhere an active (sand) load output stage ... try a search in diyaudio. Ciao Gianluca |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| What makes Nichicon "muse"/"for audio" caps different ? | percy | Parts | 2 | 3rd October 2009 05:53 PM |
| Fostex "rated input" and "music power" | hugz | Full Range | 12 | 16th March 2006 04:33 PM |
| Some final pics of "Stacks" revisited and "Askew" with stand | Andy G | Multi-Way | 2 | 3rd February 2005 06:07 AM |
| Anyone used Scan-Speak's "Flow Resistors" or "Aperiodic Vents"? | Ignite | Multi-Way | 3 | 18th November 2001 08:42 AM |
| Page generated in 0.15480 seconds (85.71% PHP - 14.29% MySQL) with 11 queries |
