| diyAudio Sponsor | ||
Id like to build a moderate budget bass amp for a pair of 16ohm 15s I have. I need 100-200 watts to drive them.
I was thinking an OTL might be tenable with them series connected using 4 6C33Cs in an inverted Futterman. Though I worry about eating my speakers. Im considering an amp using a dual 115V primary Avel 625VA 25V+25V Toroidal Transformer as the OPT as an alternative. Any advice, schematics or suggestions would be welcome.
Be sure your foil hat has a good low impedance ground. |
#2 |
Heretical suggestion is to run the 2 x 15s in parallel to give 8 Ohms so that they damp each others back EMF and to drive them with a Solid State AKSA 100W amp from here.
http://www.aksaonline.com/ If you want really top HiFi Audio Quality then get the 100W Nivarna Plus Option. If you want to know what others have said about these amps then look here: http://www.audiocircle.com/circles/viewforum.php?f=19 Doing the job with tubes is going to cost a heap more particularly if you want it to outperform what the AKSA will do. Aside: I run an AKSA 55 Nivarna Plus as a reference amp. I have managed to design and build a few amps which outperform the AKSA in most respects except perhaps in bass handling but in every case they cost a minimum of 3 to 4 times as much in parts alone. Cheers, Ian |
#3 |
Definetly heretical, and why would it be cheaper? Bear in mind I have PSU components coming out my ears. Over 40kJ worth of capacitors, though not so many OPTs. It really doesnt make sense for me to buy any more kits at this point. Im not a sandophobe, but Id like to play with tubes. If I go SS it will probably be a hopped up Aleph 2, which isnt really famous for its bass, but I have the parts.
The drivers in question are Lamdba Dipole 15s, they will be crossed to a mid in a biamp arrangement. I dont think they really require alot of damping factor? I'm thinking about a Visaton B200 for the mid. Instument is upright bass.
#4 |
Why re-invent the wheel? Use fixed bias push pull 6550s or KT88s. Should be good for 100W with a high enough B+, or you can go parallel push pull for more. Copy a classic fender design (or similar), spend $100 on a large OPT, regulate the screens and preamp power supply.
OTLs are not known for reliability, which is possibly the most important thing you want in a musical instrument amp. |
#5 |
Location: kansas city mo, and on occasion, around the world ...
Originally posted by SHiFTY
Why re-invent the wheel? OTLs are not known for reliability, ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ they are/have already been reinvented- http://www.transcendentsound.com |
#6 | |
I might think that if your speaker Q is low or your impedance is not very lumpy/steep, you might be OK. |
| Dipole bass or Ripole Bass? | MJL21193 | Subwoofers | 13 | 15th September 2008 07:42 AM |
| any electric bass players? im building a bass guitar cab | KOA | Instruments and Amps | 27 | 30th April 2007 03:49 PM |
| DBA (dual bass arrays) and active bass traps | capslock | Subwoofers | 3 | 20th August 2006 12:52 PM |
| For all Bass Junkies out there (Behringer Bass processor usage report) | VEC7OR | Digital Line Level | 5 | 27th October 2003 09:18 AM |
| Page generated in 0.09106 seconds (84.11% PHP - 15.89% MySQL) with 10 queries |
