#11 |
there has been only one time in the past 35 years in which I wish I had access to some of the analytical chemistry tools I used in Qualitative Chemistry -- to figure out the formula for Ciba's (Ilford) bleach in their reversal photography process -- a Cibachrome print still beats anything that a high end digital printer can produce.
#12 |
The Golay detector is used principally for gases. PAS uses a standard spectrometer (in the case of IR, generally an FT instrument) and is the method of choice for intractable solids, the stuff we polymer guys call "brick dust." It's easiest to understand the method by considering a dispersive measurement, i.e., frequency by frequency.
The sample is put into a small sealed chamber that has a thin port to a mike diaphragm. Chopped light impinges the sample, with the chopping frequency generally in the audio band. At a light frequency where the sample has a high absorbance, it will alternately heat and cool at the chopping frequency. That causes the boundary layer of gas near the sample surface to act as a piston, which produces a sound. The greater the sample absorbance, the louder the sound. Although PAS is generally thought of as a modern technique, the original effect was observed by Alexander Graham Bell in his so-called photophone. The effect was rediscovered and applied to spectroscopy by Alan Rozencwaig (sp?) in the 1970s. A very smart fellow named Warren Vidrine (the guy who suggested the cheat I described a few posts back!) realized that since the interferogram modulation in FT-IR is in the audio band for normal mirror speeds, PAS was a natural partner for FT-IR.
If there's a sucker born every minute, where do the rest of them come from? |
#13 |
Here's an interesting article on signal averaging. Its not immediately obvious, but apparently in the 337 the signal is averaged to improve the S/N ratio, ie. by alternately sampling the sample and reference beam signals and passing the combined signals through a low pass filter to the demodulator. The slower the scan speed, the more the samples and the better the resolution.
http://www.jce.divched.org/cgi-bin/J...sue=7&page=648 |
#14 |
I made a web page showing pictures of the original detector from the Perkin Elmer 337 and one from a Pye Unicam IR spectrophotometer.
http://chemapparati.topcities.com/PE337/Detectors.html The Pye Unicam was made later and I figured that the detector might be more sensitive than the Perkin Elmer detector and could be adapted for use in the Perkin Elmer 337. I put a detector from an old Perkin Elmer model 710B IR spectrophotometer in the 337 since the original detector in the 337 was bad. The 710B detector works, but appears to be weak; explained here http://chemapparati.topcities.com/PE337/PE337-5.htm under "Repairs and Modifications" note 6. The Pye Unicam detector has a built in preamp and a power supply needs to be set up in the 337 to power it. A voltage divider comprising a 220K resistor and a 15K resistor between the 210V regulated supply and the regulated ground would provide about 13 volts. Compare to R242 and R243 in the schematic http://chemapparati.topcities.com/PE337/Schematic.htm Maybe I could power the Pye Unicam detector from that and have the signal from the detector go into the 500K pot gain control R201 (tube preamp disconnected). |
#15 |
The pages disappeared at topcities so I started them over here:
http://www.geocities.com/antiquesci/PE337/PE337-1.htm http://www.geocities.com/antiquesci/PE337/PE337-2.htm http://www.geocities.com/antiquesci/PE337/PE337-3.htm http://www.geocities.com/antiquesci/PE337/PE337-4.htm http://www.geocities.com/antiquesci/PE337/PE337-5.htm The detectors are shown here: http://www.geocities.com/antiquesci/...Detectors.html |
#16 |
#17 |
A copy is here, too, with some information about PE 700 series IR specs.
http://antiquesci.50webs.com/index.htm |
#18 |
Good old PE intruments. Yes, I too triturated solids in "nujol" before apply the paste to salt windows and producing a graph. Organic Chemistry was good for my QP average.
Eli D. |
| Need help with tubed output for PCM1793 DAC | kkillebrew | Tubes / Valves | 17 | 30th May 2011 03:36 AM |
| How to build a tubed I to V converter ? | Yvesm | Digital Line Level | 6 | 6th May 2009 04:55 AM |
| WTB: 12B4 Tubed Preamp. | Zekk | Swap Meet | 0 | 18th March 2009 03:17 PM |
| Tubed Expression Pedal | mashaffer | Tubes / Valves | 7 | 10th April 2007 02:31 PM |
| Tubed HU | EvilGenius | Car Audio | 5 | 26th May 2006 09:54 PM |
