Will ccs work with a DHT? - Page 3 - diyAudio
Old 19th June 2006, 09:19 AM   #21
Default CCS-loaded cathoder follower
Originally posted by Giaime
It seems so strange to me. I'm using a CCS-loaded cathode follower in my preamp, unbypassed. It works, so? You don't need to bypass the cathodes of SE output tubes if you use a CCS.
Hi Giaime,
I am looking for a CCS-loaded cathode follower preamp (e.g. 12B4A, 6EM7 etc.). Could you share your circuit?
Thanks.
T.C. MA
Old 19th June 2006, 09:30 AM   #22
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
Hello, you can find all schematics online on my site, in the "preamp" section.
http://www.giaime.altervista.org/
Old 19th June 2006, 01:16 PM   #23
lndm is offline lndm  Australia
Perfect sense Giaime. A capacitor is a constant voltage device. It would only fight with a constant current source until one caved in.
Old 19th June 2006, 01:20 PM   #24
Giaime's Avatar
Notice that I was wrong when I said that, because I confused CCS under cathode followers (where load is in PARALLEL with CCS) and CCS under single ended output tubes (where load is in SERIES) with the CCS. In the second condition, the circuit won't work.
Old 19th June 2006, 01:50 PM   #25
I read in this thread about cathode loaded output stages, I thought you were talking about these. Thanks for setting me straight.
FWIW, tubecad.com has a series on them.
Would this work ? LesPaulStandard Instruments and Amps 3 4th May 2006 02:14 AM
Will This Work? sousmielie Class D 6 27th December 2005 05:53 PM
It Should Not Work ! f4bok Solid State 3 6th September 2004 05:33 PM
Would this work? JoeBob Solid State 5 18th July 2003 03:40 PM
Copyright 1999-2017 diyAudio
