Maida regulator, these results expected?
Old 5th March 2006, 08:06 PM   #1
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Default Maida regulator, these results expected?
I am building a SS HV regulator for my amp. I first started off building the Morgan Jones version of the Maida regulator, but I was suspicious of the results I achieved at first (he uses large value resistors for the divider circuit that do not provide the requisite 5mA minimum draw on their own), so I reworked it to be closer to the Maida circuit with lower value voltage divider resistors. This gives the same variability in the output voltage, and also much higher output voltage than expected. For the schematic attached, I get output voltages of: unloaded=425VDC, 300K load=419VDC, 77K load=400V. These voltages vary more than I expected, and also are much higher than the ballpark figure Vo=1.25(1+R2/R1) which would be 358 volts in this case.
So, any comments? Are these poor results, too poor for a properly functioning regulator? Is there something wrong in the circuit? Is the problem that the transistor I used has too low hfe?
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 5th March 2006, 08:31 PM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Re: Maida regulator, these results expected?
Yes, it should be much, much better than that. Don't forget that the Zener passes current into the load, so not only must the load draw enough current to make the 317 operate correctly, it must also sink the current from the Zener.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 5th March 2006, 09:40 PM   #3
Giaime is offline Giaime  Italy
Giaime's Avatar
Send a message via MSN to Giaime
I've built this, and it works very well.
Old 5th March 2006, 10:04 PM   #4
On Hiatus
SY's Avatar
One other thing, I don't know what the dropout voltage is for the HV version, but you could be pushing that. Try increasing the Zener to a 10-12V unit.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 6th March 2006, 02:16 AM   #5
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
LM317 always need around 15mA through it ,for propper operation;
trick is just in output-adjust resistor;
I always use there max 91 Ohm (1,25V/91 ~13mA)
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 6th March 2006, 02:42 AM   #6
leadbelly's Avatar
Thanks for all the suggestions. It appears that the 4.7K zener pass resistor was too small and was allowing enough current to pass through the zener to satisfy all my small test loads by itself. I think I will go with a 15K zener pass resistor, 12V zener, and an even heftier voltage divider to increase the draw on the LM317.
Maida regulator, these results expected?Hide this!Advertise here!
Maida regulator Andrewc556 Tubes / Valves 21 31st December 2010 04:29 AM
Using a Maida Regulator with a CCS BL21DE3 Tubes / Valves 4 17th July 2008 05:42 PM
Maida regulator billr Tubes / Valves 15 23rd September 2007 04:19 PM
Maida's regulator mark_titano Tubes / Valves 3 29th January 2006 03:26 PM
Copyright ©1999-2017 diyAudio
