diyAudio Sponsor
Old 4th March 2006, 10:29 AM   #1
Default Booster Amps
REcently i am plagued by the need of more power
At the moment i am using a 6c33a to drive my speaker. IT not enough eventhough my speakers are 100db. Don't bother asking my hall and soundlevel seems kill most amp under 10watts of power.
At one time Altec and cinema amps employ booster amp to boost the power of the main amps. Something like a 1570a.
Now can i use a stepup trans say 1:5 or a directly into a 833a. And have the 833a separately? I presume it should be do able.
This way when i need the power just connect the 6c33 into the 833a and have way ample power. I have the 833a and the sockets aready so cost is not a problem as well as the trans and caps.
Would this be a better way or should i just go build a big *** 833a amp?
Also would tubelabs mosfet be able to be use after the stepup trans? I look possible. Just need to check on this.
NIcholas
Old 4th March 2006, 11:23 AM   #2
Send a message via AIM to DigitalJunkie
http://geek.scorpiorising.ca/GeeK_Zo...p?topic=2035.0
Old 4th March 2006, 11:37 AM   #3
At one time Altec and cinema amps employ booster amp to boost the power of the main amps. Something like a 1570a.te:
Actually you are incorrect. The Booster amp tap is nothing more than a parallel signal arrangement to drive additional amplifiers to drive additional speakers.
I would be more than happy to find some large system schematics to back up the point.
Old 4th March 2006, 02:05 PM   #4
Do you have any schematics for this?
I am looking for it.
I suspected it was a normal amp say a 6v6 amp, signal out from opt feed into a stepup trans and drive the grid of the bigger tube
Is this something like this?
Old 4th March 2006, 02:12 PM   #5
It is nothing more than a way to parallel the input signal and send it to another amplifier.
Old 4th March 2006, 11:11 PM   #6
anatech is offline anatech  Canada
anatech's Avatar
Hi Joe,
Correct, and Bogen still does this. The input jack is wired directly to the boost output in some amps.
Nick,
Consider just building a bigger amp. It will sound better than what you are thinking of.
-Chris
Old 6th March 2006, 12:48 AM   #7
jeff mai's Avatar
http://www10.big.or.jp/~dh/work/87082.html
I believe this was adapted straight from a schematic in a 1930s UTC or Stancor transformer catalog. It was called a "booster amp".
Old 6th March 2006, 01:10 AM   #8
Jeff
Thanks for the link
This was what i was looking for. A booster amp.
Old 6th March 2006, 01:11 AM   #9
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
booster amp in ole dayz was exactly like OP means....
one weeny little amp feeds IT to grids of one big output stage
I saw not just one schmtc with 211s and 845s in PP
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 23rd May 2011, 11:18 PM   #10
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
I think the Altec booster amp was the 287F, it used a pair of 845s. I assume you had to mate it with a 1568 amp or something similar to drive it.
bass booster jevincuevas Everything Else 1 29th September 2008 10:27 AM
Booster amp Marty99 Solid State 1 20th September 2008 01:41 PM
FM booster MaXiZ Everything Else 2 19th December 2006 06:01 AM
Audio Booster Byam Solid State 2 20th October 2005 06:20 PM
TV booster Cephas Everything Else 1 1st May 2002 03:45 PM
Page generated in 0.09760 seconds (76.43% PHP - 23.57% MySQL) with 10 queries
