| diyAudio Sponsor | ||
I built some 2A3 monoblocks that I'd like to place near my speakers. Because of where things are placed, I need to run about 15 ft of cabling from the preamp to these.
I currently have a passive pre that obviously will not work. I'd like to build a 12B4A preamp to drive the cables. I want to use a preamp transformer (Sowter) that is 4:1 and I think a good match for the valve. I'd also like to reverse the output so phase is preserved. Using an op point of 80V, 15mA, -10, ra = about 1200ohms. So with the 4:1 transformer, I expect that this will drive the cables at about 75ohms. Does this make sense? Thanks Dan |
#2 |
Is the transformer designed to be happy passing 15mA? Somehow, I doubt it. It's not the end of the world, though. Fit a semiconductor CCS in the anode circuit and feed the transformer via a capacitor.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#3 |
Use RG-62U coax. 92 ohm . It has half the capacitance per foot of regular coax (about 15pF per foot vs 30pF). You may not need a line driver. I am using 25 foot runs to my power amp with no driver.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#4 | |
I also want to use a silver foil to make the long interconnects. So that's why I'm wandering down this path ( |
#5 |
Fair enough. Carry on.
#6 |
Hi Dan,
Why do you want to drive 75 ohms? That’s only good for video. IMO you don’t need 15 mA through that tube and a 4:1 transformer for a line driver (unless you want several volts into a 600 ohm load). 5 mA – 10 mA will suffice me think and the tube will last a lot longer. But you can experiment with that anyway. Cheers |
#7 |
what kind of interconnect is that?
i have the same setup where my amps are 5 meters away from the rest of my gears. maybe i'm deaf but using a passive DACT fed by my clearaudio phono stage, i didn't have to worry bout the long run. i also have a 12B4A pre and i just invert the speaker terminals which is free i've have a 5 meter DIY interconnect, OFC copper in teflon, hand braided and a commercial Quantum (it says made in Germany) 5 meter interconnect which is dirt cheap. both are terminated with Eichmann Bullet Plugs. |
#8 |
I came to 75 ohms simply because ra divided by 4 squared equalled that.
For cables, I want to try one of the silver foil interconnect recipes in Allen Wright's cable cookbook. Dan |
#9 | |
#10 |
True, but the effect depends largely on the actual load line. And if the next amp has an input impedance of say 47K, I don’t see a problem.
But anyway most of the (AC) current is supped up by the magnetisation current of the transformer at low frequencies. So the difference can be noticeable at low frequencies and at high frequencies due to the cable capacitance. But IMO it is worth a try. Cheers |
| 6j5 dc coupled to 12b4a as 2a3 driver | alexg | Tubes / Valves | 23 | 28th October 2008 11:35 PM |
| Line driver? | audiobahnkid592 | Car Audio | 7 | 15th August 2007 12:23 PM |
| Sub Line Driver | rampage101 | Car Audio | 9 | 18th October 2006 06:39 AM |
| one more 12B4A preamp | resident | Tubes / Valves | 76 | 9th March 2005 06:49 PM |
| line driver/preamp | offroadbum | Car Audio | 7 | 21st February 2004 07:53 AM |
| Page generated in 0.11623 seconds (81.31% PHP - 18.69% MySQL) with 11 queries |
