| diyAudio Sponsor | ||
I have seen it mentioned in threads about the benefit of using a separate transformer winding for the driver tubes than the power tubes of an amp rather than the same secondary. I mean of course specifically about instances where a single one will do and not designs where heater-cathode voltage is the issue. What's the basis of this improvement? Is it poor noise separation between heater and the anode/cathode? Is is that lower AC currents in the wire reduce EMF? I am trying to decide if it is worth the bother in my amp, the draw for the heaters of the driver tubes is 1.2A and the draw for the power tubes is 3.0A.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#2 |
I don't know what kind of tubes you're using on your amp (DHT, IDHT) but for DHT tubes like the 2A3 when using cathode bias, I believe separate windings are required.
Having said that, I also built an EL34 amp and shared the same 6.3V heater winding with the drivers (no heater elevation) and I did not have any problems, or so I think. I'm also interested in the logic behind it. |
#3 |
Oops, sorry, I meant indirectly heated. I can see that there are other issues for DHT.
#4 |
Heater windings carry high current. This means inductive radiation can be significant where windings are near stages with low level signals. Hum is the problem. Mainly with phono preamps. You can twist the windings, and you can connect them with separate cable runs from the source. This way you avoid a string of heaters running from the same cable which then carries a high current.
| SPMSU for heater supplies | ruffrecords | Tubes / Valves | 4 | 12th July 2009 08:52 PM |
| Floating heater supplies | duderduderini | Tubes / Valves | 8 | 27th August 2007 01:25 PM |
| Common mode filtering for heater supplies. | jnb | Tubes / Valves | 2 | 13th July 2007 04:16 AM |
| stereo push pull amp one heater supply for power tubes | nhuwar | Tubes / Valves | 5 | 3rd February 2007 02:32 AM |
| Common Mode Chokes for Heater Supplies | ppereira | Tubes / Valves | 7 | 29th January 2006 01:45 PM |
| Page generated in 0.07744 seconds (72.81% PHP - 27.19% MySQL) with 10 queries |
