| diyAudio Sponsor | ||
#21 |
To get your feet wet I would (personally) recommend that you get the Bottlehead Foreplay, build it, tweak it and then go for the "build it from scratch" preamp (or amp). The Bottlehead site can be found here:
http://www.bottlehead.com/ There is a forum with lots of experienced "Foreplay builders" as well as a plethora (did I say that?) of tried and true tweaks for the preamp. This will get you smelling solder fumes and get your feet wet and is a good design. Whichever path you choose, enjoy.
Gavin |
#22 |
I just a response from harbuch on the transformer
$112.15 as EI or $77 as toroid. add 10% for GST in Australia. good price ?? As for G's post, i looked at the bottlehead foreplay and i know there is heaps of info out there on it , but i would rathe get right in there and build one from scratch. I've already learnt heaps just in researching this much Cheers Fbleagh |
#23 |
Hi Fbleagh,
The transformer prices sound reasonable to me, better than anything I have been able to find in Australia. What was the spec? Was it similar to what Brett posted for your original project? Primary: 230V Secondary 1: 330V - 0 - 330V at 100 mA for the B+ Secondary 2: 6.3V at 2A for the GZ80 Secondary 3: 8V at 1.5 A for the signal tubes Regards, Tim |
#24 |
FBLEAGH,
Since you're new to tubes, please start off on the right foot and realize that there is no need to spend lots of money on tubes. Get a "used/tested good" pair of 6sn7's and be on your way. Also, two 6CG7, or even four 6J5's are options if you can't find cheap 6sn7's. Preamp tubes almost never go bad, and due to the number of people obsessed with "NOS", you can pick up used ones for very little cash. You will never know the difference (because there is none). Just because RCA put a red colored base on a tube doesn't mean it "sounds" better, or works any better. To answer your question, there is no difference in sound between brands either. Have fun. Joel
#25 |
timc, yeah it was the same spec as the one listed above
ie. Primary: 230V Secondary 1: 330V - 0 - 330V at 100 mA Secondary 2: 6.3V at 2A Secondary 3: 8V at 1.5 A I am finding that there is much larger range of 12ax7's out there compared to the 6sn7's are they a good tube ? I know there is a difference in pinouts etc but what sonic differnfce or different driving attributes do they have ? |
#26 | |
diyAudio Senior Member
I'm not to claim one tube is better then the other,but saying there that there is difference? Get real,please.
Frank |
#27 |
There is a difference in gain. 6SN7 has an ideal voltage gain of 20, 12AX7's is 100. As far as "drive" - I assume you mean current capablity? - 12AX7's idle at under a milliamp, 6SN7's at 8 or 9.
Any old tube manual would be a good investment for you. They are cheap. Joel |
#28 | |
Get real? My thoughts exactly. Cheers, Joel |
#29 |
hi,
I agree,we are all deaf.
Frank |
#30 |
Ok i've been doing more thinking and research.
2 questions 1) instead of getting a custom xformer for this, is there a multi purpose tube transformer i can get ?? ie one i can use on later projects ?? i would imagine lots of secondaires that u can combine. 2) are there any other designs that are worth looking at ?? other topologies etc ?? I jsut want a nice sounding preamp, that i can tweak and modify later, but is a good starting point. And the kit idea is pretty much out as i cna do this much much cheaper as DIY. I have my sources Cheers FBleagh |
| FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner | joe-electro | Swap Meet | 0 | 31st May 2009 05:14 PM |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 05:52 AM |
| tube preamp using submini tube | unclejed613 | Tubes / Valves | 11 | 19th August 2007 08:14 PM |
| Is it possible to get "tube sound" with just a tube preamp and chipamp output? | Spasticteapot | Instruments and Amps | 43 | 15th May 2006 06:28 PM |
| need diy tube preamp (line-stage) recommendation and general tube advice | Musiclover4 | Tubes / Valves | 15 | 24th November 2005 02:19 AM |
| Page generated in 0.15180 seconds (57.89% PHP - 42.11% MySQL) with 11 queries |
