diyAudio Sponsor
Old 11th November 2002, 10:24 PM   #11
Ok thanks guys,
Now i've got something to start on
btw do you think this a good design to start with ?
Is this going to be easy to modify and pay with later ?
I was gonna build it using the tubebuilding PTP boards, good idea ?
also where can i find some good info on tube theory ? eg topologies, basic design ideas etc
oooo 1 more thing, how easy will it be to add a decent selector ciruit and possibly some tone controls later ( and where whould the tone controls fit i the circuit )
THanks agian
Fbleagh
Old 11th November 2002, 10:43 PM   #12
diyAudio Senior Member
fdegrove's Avatar
Default TUBE START UP.
See here amongst others:
Tube Question, what the....?
Other then that you said it to be a preamp I don't know what circuit you picked.
Care to tell us some more?
Depending on real estate,why not?
You mean these phenolic boards with a row of solder lugs?
Those are easy and give better soundquality then PCB.
Selector switch is no problem but tone controls never interested me.
Can be calculated though.They can be done within a feedbackloop or passively with specially tapered pots.
When passive they can go at the inputs.
Is this for a guitar preamp stage or similar application?
Let us know what you want to do and we'll take a look.
Frank
Old 12th November 2002, 12:14 AM   #13
thanks for your response fdegrove
I am looking a the line preamp design 2
Looks nice and simple.
as for the application i am looking at, it will be used as a preamp for my solidstate power amp.
and i want to add a selector switch ( cd, pc, dvd, tv )
and an extra set of pre amping outputs to goto my headphone amp.
hmm you mentioned that this could be used as a guitar preamp hmm that could be cool, i ve started learning bass and need an for practicing at home
Old 12th November 2002, 12:29 AM   #14
fdegrove's Avatar
Default PREAMP
The circuit on the picture above will work even better than #2
and can be arranged much the same way.
Where it says "stepped" on the picture you put the volume control.
It has a very good sonic reputation as a topology and the 6SN7 is one of the best sounding octal tubes around and still in production.
Moreover it can drive much longer interconnects than the anode follower as proposed in #2.
Gain will be more then ample for all known sources and you have all the required components values for it to work right here.
Might you have more questions,just ask.
At the end of the day it is your call,so I'm only ging advise here.
Frank
Old 12th November 2002, 01:17 AM   #15
Ok so the above design uses both halves of a 6sn7gtb.
i s that right ?
and then i make another circuit the same for the left channel.
cool.
i understand ( basically ) what is going on in the bottom half but what is it doing in the top half , ie what is the second tube half doing ?
BTW thanks for all you help
just finshed reading http://www.eecs.umich.edu/~mmccorq/t...roduction.html -- good intro to tubes, i know feel i ahve at least some understanding of whats going on
Old 12th November 2002, 01:36 AM   #16
also what are good 6SN7GTB's to look for ?
RCA, GE, Raytheon ??
Old 12th November 2002, 02:50 AM   #17
rca 5693 red base (6sn7) Arguably the best! $100-150 for NOS pairs.
Old 12th November 2002, 03:12 AM   #18
Or get some 12SX7's.....
Dave
Old 12th November 2002, 03:39 AM   #19
fdegrove's Avatar
Default *SX7
No need to shout it from the rooftops.
Seems to me someone is browsing a databook.
Indeed,a very good alternative.
No need to spend big bucks on tubes unless you want to build a very,very good preamp in the first place.
And you all know my recipe for that by now,don't you?
Worthy of consideration as well: *SU7.
There're bound to be others but I need to look them up.
As far as the diagram posted goes it is an SRPP (shunt regulated push-pull) in it simplest form and more than adequate for the task.
The top tube basically replaces the classic anode resistor and isolates the bottom half from the PSU.
Low output impedance and better dynamic range are the result but it is highly dependent on a well regulated PSU.
More about it later,
Frank
Old 12th November 2002, 04:16 AM   #20
As I am fairly new to all of thiswhat would you guys suggest as a good tube to start with preferably easy to get hold of and reasonably cheap, but with some good tuberolling options later.
fdegrove wrote:
would you be so kind as to point to where i can read about this recipe for preamps
Cheers guys, youve been a great help
FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner joe-electro Swap Meet 0 31st May 2009 05:14 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 05:52 AM
tube preamp using submini tube unclejed613 Tubes / Valves 11 19th August 2007 08:14 PM
Is it possible to get "tube sound" with just a tube preamp and chipamp output? Spasticteapot Instruments and Amps 43 15th May 2006 06:28 PM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 02:19 AM
Page generated in 0.11336 seconds (81.70% PHP - 18.30% MySQL) with 11 queries
