Using one half of double triode
Old 28th February 2006, 01:08 PM   #1
cs is offline cs  United Kingdom
Default Using one half of double triode
If I have a double triode (like the 12AX7) but only want to use one half, is it best to power up both heaters ?
I am thinking that running only one heater would mean the valve never gets up to its correct working temperature, perhaps ?
Old 28th February 2006, 01:41 PM   #2
tade is offline tade  United States
Send a message via AIM to tade
If it is directly heated then it shouldnt matter though i should think it shouldnt matter reguardless. Either the elctron is jumping off of the filament itself or a hot pieof metal which is being very closely heated by a heating filament. Either way you should be able to run one by itself.
Of course you could heat the other one up for a little extra glow.
I wonder if you could use the unused portion as a guide which would cancel distortion caused by vibrations in the tube?
Old 28th February 2006, 04:12 PM   #3
kevinkr's Avatar
There should be no problem at all with heating just one section of the 12AX7, the only thing that matters is the cathode temperature of the one that is being used. Just make sure that you have approximately 6.3V at the filament, dc will be quieter if this is being used in very low level applications due to reduced hum pickup.
As for the vibration cancelling idea, you can't assume that the two sections will be equally microphonic or have exactly the same resonances. If this is a concern I would isolate the socket from the chassis and use superflexible stranded wire to connect it to your passive components, alternately just build the whole thing on a mechanically isolated subchassis.
Tube dampers help to a very limited extent as do tube caps.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th February 2006, 04:56 PM   #4
how do microphonics affect the sound? Do they vary interplate distances significantly?
Old 28th February 2006, 06:18 PM   #5
On Hiatus
SY's Avatar
Kevin, FWIW, I've found nearly a 6dB improvement in microphonics with a well-balanced phono input using two sections in the same envelope, at least at lowish frequencies (below 1kHz). The tradeoff is 3dB more hiss for the same tube count, but the effectiveness of this trick surprised the heck out of me.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 1st March 2006, 09:56 AM   #6
i_should_coco is offline i_should_coco  United Kingdom
i_should_coco's Avatar
If you only use one half, you should only apply heater power to that side.
Running the tube heaters without drawing any current risks poisoning the cathode.
Old 1st March 2006, 11:25 AM   #7
Thanks for all the useful responses.
On a related question, another option I have considered is to connect the two triodes in parallel, and thus halve the impedances.
Are there any problems in doing this, and will the two tubes share the current between them OK ?
Old 1st March 2006, 01:34 PM   #8
You should be fine. You'll need to halve your plate/cathode resistors (assuming using a resistor loaded common-cathode stage). You might have to try a few tubes to get ones which balance well.
You will double your gM by paralleling, which will lead to a reduction in noise. Gain will remain the same, due to the halved effective plate resistance.
Old 1st March 2006, 04:10 PM   #9
kevinkr's Avatar
Hi Sy,
I have tried the same approach (differential input) and also found it worked in an early phono stage I designed, while it was very effective against external noise pickup, it didn't seem help the issue of microphonics at all.
I ultimately ended up running two 12AX7 per channel with all sections in parallel with individual cathode resistors to assure current sharing between all of the sections. I think in total this front end was about 12dB quieter (measured) overall than a single section, but had the disadvantage of much higher miller capacitance. I was using a HO moving coil at the time and the higher capacitance wasn't an issue - with many mm and low capacitance cable it would not be an issue either.
The lower noise of course was due to the gaussian nature of the noise generated by the triodes, the lower effective source impedance, and lower resistances required for the plate load resistor and RIAA network that followed.
Using one half of double triodeHide this!Advertise here!
Seeking Pentode-Triode with a 12AX7 half... jon_010101 Tubes / Valves 12 14th April 2009 11:10 PM
what double triode is less microphonic ? inertial Tubes / Valves 49 19th December 2008 09:21 AM
Another 3f4 spice triode model: 5718 submini triode wa2ise Tubes / Valves 0 5th September 2008 04:31 AM
a single double triode and two chanel? killerfishes Tubes / Valves 2 14th June 2005 12:16 PM
Heating only one half of a double triode bequerel Tubes / Valves 9 28th October 2004 04:43 PM
