diyAudio Sponsor
Old 25th February 2006, 10:40 PM   #1
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
Default On - board supply ?
For some time i have worked on high voltage transistor amp.Now i
started to draw PCB , and have one question : is it better to put high voltage supply on a separate board ? It is common for electros to leak electrolyte ?
Best regards ,
Lukas.
Old 26th February 2006, 12:56 AM   #2
Send a message via MSN to DoomPixie
i always build the power supply onto its own PCB, even if the rest of the amp is wired p2p..
I dont think its common for electrolytic capacitors to leak no, only if they are old, if they are leaking they should be replaced because you run the risk of them explodeing...
Owen
F3 pcb + power supply board for sale h_a Group Buys 7 26th February 2009 05:14 PM
F3 pcb + power supply board for sale h_a Swap Meet 6 23rd February 2009 04:14 PM
Parasound HCA-500 Amp and Power Supply Board john65b Swap Meet 0 4th February 2007 05:34 PM
Denon DCD-755 supply board schematics m127 Digital Source 1 2nd April 2004 09:10 PM
Symetrical power supply PCB board needed supernet Solid State 6 19th June 2003 09:24 PM
Page generated in 0.07642 seconds (71.07% PHP - 28.93% MySQL) with 10 queries
