diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   Name that EL34! (http://www.diyaudio.com/forums/tubes-valves/74764-name-el34.html)
LowRedMoon 25th February 2006 10:59 PM
Name that EL34!
The 2 tubes linked below came from a Dynaco ST-70 that I bought. There are 2 pairs of them. To thisgreenhorn, they look like Mullards. They are stamped "Made in Great Britain." One has a single halo getter and the other has a double halo getter. There are really no other distinguishing markings on them (other than the pin numbers, which I doubt are neccessarily distinguishing).
Tubes in general are pretty new to me, so please try not to laugh too hard at my inability to accurately identify these tubes.
I also received 2 RCA black-plate 7199s with the amp that look mint!
Tube 1 with single halo getter:
http://i11.photobucket.com/albums/a1...---made-in.jpg
Tube 2 with double halo getter (the second image makes the halos look stacked atop of one another - this is due to the angle of the snapshot):
http://i11.photobucket.com/albums/a1...--made-in-.jpg
SHiFTY 26th February 2006 12:32 AM
Look like Mullards to me.
Have a look for a brown two line code near the bottom of the glass it should read Xf2 , 3 or Xf4 or similar... That would tell you for sure.
Also be careful of the printing- if you clean these tubes, don't wipe off the print!
LowRedMoon 26th February 2006 12:34 AM
Thanks, Shifty.
Tube #2 with double halo getter is certainly a Mullard:
http://i11.photobucket.com/albums/a1...---closeup.jpg
Tube #1 - with single halo getter is marked "GT BRITAIN," has stapled plates, and a crosshatch on the top of the glass:
LowRedMoon 26th February 2006 12:56 AM
In my haste, I neglected to closely inspect tube#1's partner. It appears to be GE branded with a marketing name that I don't recognize, but is otherwise the same:
http://i11.photobucket.com/albums/a1...---closeu2.jpg
LowRedMoon 26th February 2006 06:52 AM
More images of the unknown GE tube:
http://i11.photobucket.com/albums/a1...---closeu4.jpg
Resources saved on this page: MySQL 18.75%
