diyAudio Sponsor
Old 24th February 2006, 09:52 PM   #1
gemby is offline gemby  Croatia
Talking Mini-p1 tweaks
I boght few weeks ago litlle nice hong-kong amp. For now it stands in my work room next computer playing mp3-s...in first few days sound was a little bit disapointing, but after week of listening it gets better more and more.....
Here are photos of amp http://gallery.galaksija.org
I am asking if anybody has schematics, and also would like sugestions for moding...
I am planing:
- make relay based input selector (i got few mini siemens 6v relays)
- make discharging circuit for power off
- make power on delay with standby switch
- pull out those ugly blue LED-s in sockets of 12AX7-s
- replace block condensators in signal path with beter ones (sugestions?)
- replace electrolits in power suply (sugestions, values?)
- make snubber circuit and replace diodes in greatz (what tipes, values)
- make ac stabilised circuit for heating 12ax7
- make power stabilizer and beter filtration of voltage for 12ax7
- replace 12ax7 with Ei brand 12ax7
- replace EL34 with JJ brand EL34
Any sugestions for sepakers? Energy RC-10 ?
Old 25th February 2006, 12:16 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
So what is name and number of this amp?
There has got to be some identification plate on backside .... ??
lineup
Old 25th February 2006, 01:09 AM   #3
Hmm, this is some no name chinese copy of S.E.T.Music El34 amp
Old 25th February 2006, 02:23 PM   #4
Svein_B is offline Svein_B  Norway
This amp seems to be a variant of the Yarland FV-34Biii
PP triode mode, paraphase driver/phase splitter.
I would suggest as the first mod to remove the BLUE LED's under the driver tubes.
I understand that the paraphase phase splitter may need adjusments of the blue trimmer pots when rolling tubes.
I have been thinking about modifying a similar amp to LTP driver stage with CCS, but as long as the sound is good ...
Svein.
Old 25th February 2006, 09:17 PM   #5
Yep, blue LED-s are going out first :-)
RCD-971 tweaks Bill Fuss Digital Source 5 29th October 2007 01:17 AM
Tweaks vs. insanity (yes, just another thread about tweaks; but there are some links) Rodeodave Everything Else 7 28th February 2007 03:05 AM
Tweaks HarryHaller Everything Else 0 24th February 2002 01:47 PM
Page generated in 0.07978 seconds (70.17% PHP - 29.83% MySQL) with 10 queries
