| diyAudio Sponsor | ||
#11 |
arnoldc,
could be why i'm reading only 260volts at the plate because of the 10k resistor. can i still get away with the needed voltage on the driver if i remove this resistor? also, if i lower the cathode resistor on the 2A3, will i not be able to get the 45 volts to drive this output tube? what are now my options with this mains transformer and said tubes? please suggest. thanks |
#12 |
i guess not. you lower your cathode resistor, you pull more current, which means your B+ is going down even further.
Why are you so stuck with this power supply? What's the transformer secondaries? What's the filtering topology? (CRCRC, CLCLC, LCLC, etc) ps. If you're stuck with that power transformer *and* using tube rectification, ditch the tube rectifier and use SS. You will get a higher B+ pps. it's just not enough... if the 2A3 grid is 130V from the SRPP, you want the cathode to be 45V above that, 175V. 175V / 50mA = 3K5 ohms cathode resistor. But you actually need 4V + 130V + 45V + 250V = 430V
#13 |
my filtering section after the 5u4g tube is composed of 20uf cap then 10H choke then 220uf cap which gives me a b+ of a little over 350volts. will changing the caps give me a higher b+? sorry but im just a newbie. and thanks for the reply.
#14 |
btw, i dont want to spend more as much as possible so im trying for this transformer to work.
#15 |
why sorry? we are all newbies here. Just wait when Sy, Thorsten, and Frank, and many others post in a thread
two options- 1. Use another power transformer 2. Ditch the 5U4, and go SS |
#16 |
ok. please suggest what ss rectifier to use? can you help me with the power supply schematic? what will be its effect on the sound compared to tube rectifier? thanks
#17 |
what is the secondary of your transformer?
| capacitor coupled vs. direct coupled ouput | hugobross | Solid State | 11 | 21st January 2011 01:56 AM |
| 6sn7 direct coupled and transformer coupled | neazoi | Tubes / Valves | 3 | 23rd May 2008 03:30 PM |
| 6922 transformer coupled | Andersen | Tubes / Valves | 12 | 9th April 2008 02:47 AM |
| My first amp - a direct coupled 2A3 | Wardsweb | Tubes / Valves | 51 | 3rd August 2003 04:22 AM |
| Can someone explain parafeed & direct coupled & a.c. coupled? | mwmitchell | Tubes / Valves | 2 | 11th September 2002 01:10 PM |
| Page generated in 0.08551 seconds (72.38% PHP - 27.62% MySQL) with 10 queries |
