diyAudio Sponsor
Old 5th May 2011, 07:34 PM   #11
I have bought a Mercury 2000 tester without any docs, and I need your help.
Could you share your manual with me ??
My email is lklunder3@gmail.com
Thank's in advance
Old 6th May 2011, 02:12 AM   #12
TheGimp is online now TheGimp  United States
TheGimp's Avatar
Ping....
Old 6th May 2011, 09:00 AM   #13
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Mercury 2000 : Pacific T.V. - Online Schematics
http://pacifictv.ca/schematics/mercury2000schematic.pdf
http://pacifictv.ca/schematics/mercury2000cal.pdf
http://pacifictv.ca/schematics/mercury2000chart.pdf
http://pacifictv.ca/schematics/mercury2000chartsupp.pdf
Arne K
Ars longa, vita brevis
Old 8th May 2011, 10:17 PM   #14
Default Mercury 2000 tester operation manual
Thank you for your help.
I have a doubt about how using this tester, I have followed the chart, I have tested some valves and several that I know are in good condition, I expected that the needle mark on the green zone and this remains in the red zone. May be this correct??
I followed the instructions for calibration and adjustment.
I thought that on a good valve, the needle should always mark on the green zone.
Also I do not understand the scale of Em, when this scale be reads high and low scale.
You know about these doubts.
Old 9th May 2011, 05:21 PM   #15
TheGimp's Avatar
The Green and red zones are used on simple emission testers It is not used for Gm measurements.
The Mercury 1000/2000 test sets attempt to measure the tube Gm and display it on the meter which is calibrated in two ranges (low and high). The low scale gives better resolution of measurement below 5000 iirc. This is accomplished by changing the bias on the tube under test.
One has to compare the Gm value called out in the test chart to the value on the display to know if hte tube is good or not.
Green is only used for emission testing such as diodes.
Old 9th May 2011, 07:55 PM   #16
DIY !
Cobra2's Avatar
Default Manual
2000 manual
Arne K
Old 12th May 2011, 08:14 PM   #17
Hi Arne,
Thank you very much !!!
It's very usefull for how use the tester.
Thank's again.
Tube Tester's Space1 Tubes / Valves 17 2nd June 2009 08:54 PM
Tube Tester jtwrace Tubes / Valves 5 8th September 2007 04:47 PM
Tube tester Sjef Tubes / Valves 6 29th January 2007 08:38 PM
tube tester TJ Tubes / Valves 11 5th April 2005 02:23 PM
help using Tube Tester ebarker2 Tubes / Valves 3 31st January 2004 02:30 AM
Page generated in 0.08983 seconds (76.75% PHP - 23.25% MySQL) with 11 queries
