power transformers in series
Approximately, yes. However, if one of the tansformers delivers slightly less voltage than the other, or behaves differently when loaded, the other transformer will sink some current in the 'different' transformer. So I would be very careful.
(and remember that you'll need to have the phases of the windings correct, or otherwise you'll have an instant short-circuit)
ok it s not a schottky diode but a 1000volt diode
test :
1-take just 1 transfo +BYW96E bridge +tube diode(for turn on
delay if i understand)
2-without load check temp after 1 hour (max. 40 to 50 C )
3-if ok try maybe 25ma after 50ma after 75ma to find the
max load for 1 transfo
The circuit of the diodes is the same as in this attached file. It is a nice solution if you do not have a centertap on your transformer. I found this solution in a magazine that is about 50 years old and you can still use it for free
