| diyAudio Sponsor | ||
Is it normal when I turn on my tube amp, there is a short rumbling sound from the speaker?
Here is the schematic of the amp: http://www.geocities.com/hai_vu1/schematic.JPG It is a push-pull using 2 300B tubes. |
#2 |
Are the two cathodes of the input tube connected to each other?
In the schematic they are not, but they must be...
Jorge |
#3 |
yeah, that would do it.
#4 |
So?
Jorge |
#5 | |
Sorry for the delay. But I was looking at the schematic myself and the input stage doesn't look like a diff stage so I am not sure if they are supposed to be connected together. I haven't gotten a chance to open up the amp and look at it yet. But I have a picture of the amp internally: http://www.geocities.com/hai_vu1/mingda.JPG I am not sure if the picture can tell. By the way, the initial noise because I think I don't have any mean to slow down to initial inrush current at start up. So I have to come with a way to limit the current when turned on. The simplest way is to use a thermister between the rectifier and the power decoupling caps. Thanks. |
#6 |
The input stage appears to want to be two triodes connected in parallel. So since you have plates tied together, grids tied together, you absolutely need to tie the cathodes together. Trying to use the capacitor as a ground return on that second section will definitely not benefit you!
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#7 |
I suspect the error is in the schmatic only and not in the wiring of these amps. I also can not see how this would cause instantaneous startup noise since the strapping of both cathodes of the input 6SL7 is meaningless until the cathode reaches emission temperature which will take a good 8-10 seconds.
I am also aware of this problem and would like to know the sulution. A friend has it in his MingDa and is too far for me to get the amp to sort out on my bench. He has reported an accompanying flash inside one of the 300B tubes. Unfortunately he has ElectroHARMonix gold grid 300B's in his amp and in my experience with this brand 300B, they do this normally. Pure overhyped garbage IME.
I.Q.Test. Have you ever purchased a recreational snowmobile? |
#8 | |
As for the tube flasing when turned on, is this normal or could signal some abnomality? Thanks. |
#9 |
Andy,
You have PM.
#10 |
Hi Andy,
Any chance of trying another pair of 300B's? You will need to use them later at worst, at best this will fix your problem. -Chris |
| 2sa970/2sc2240 sudden HFE DIP | haseeb | Solid State | 5 | 26th June 2008 11:29 PM |
| tape head sudden magnetization, help please | federico moreno | Analogue Source | 13 | 14th June 2006 06:31 PM |
| Did someone else than me noticed the sudden jump into high-end made by Adire Audio? | simon5 | Subwoofers | 23 | 2nd May 2005 11:08 PM |
| Philips CD650 sudden failure! | homer09 | Digital Source | 22 | 21st May 2004 08:40 AM |
| How can I reduce mechanical turn on and turn off noise? | soundNERD | Chip Amps | 8 | 28th October 2003 01:43 AM |
| Page generated in 0.11118 seconds (77.69% PHP - 22.31% MySQL) with 10 queries |
