diyAudio Sponsor
Old 17th February 2006, 06:30 AM   #1
kalel is offline kalel  United States
Default Symphonic Line Die Erleuchtung Reference
Having very little knowledge about tubes yet owning a tube pre-amp, I need some advice, please. I purchased a used SL pre-amp a little more than a year ago. Not using my brain I left it on 24/7 for about the entire time that I have owned it. Needless to say, I am replacing my tube set.
Here's the question. I have removed (12) Svetlana 6N1P tubes and (4) Ei EZ-80 rectifiers. Shoud I replace everything with the exact name brand tubes or is there something better out there? Any advice is greatly appreciated. Thank you.
W-
Old 17th February 2006, 06:35 AM   #2
diyAudio Moderator Emeritus
Bas Horneman's Avatar
The 6n1p is quite a good sounding tube. There are not many different brands of those anyway. Maybe 2 factories in Russia built it.
But you could experiment if you like (ECC88 is fairly close to 6N1P..the 6N1P has higher filament current and has very very little microphonics). However with 12 tubes that is quite expensive. And in my opinion not worth it. You could play around with different EZ80's but that makes much less of a difference.
Old 17th February 2006, 11:06 AM   #3
just out of curiosity...does anyone know why this preamp uses such large amount of tubes? there are 24 triodes in there...
Old 17th February 2006, 12:37 PM   #4
RIP
pedroskova's Avatar
I doubt that you need to replace the whole set. I would think that a careful swapping around of tubes might identify which tube is at fault...whatever that fault may be - you didn't explain your problem.
Old 17th February 2006, 01:40 PM   #5
Send a message via MSN to DoomPixie
If there is no fault.. then the tubes are probably still OK. in which case your best bet would be to work out what all the tubes are used for and then you can experimant with different 6n1p / ECC88's in different stages of the preamp, a schematic would be usefull here, I am also interested as to why there are so many tubes in there. For comparison, my 6n1p preamp uses 2 6n1p and 1 EZ80 rectifier tube's...
Owen
Just thought, it could use a seperate EZ80 for left and right channels... and mabey seperate again for the phono stage left and right.. but this would just be totall overkill imo..
Old 19th February 2006, 01:48 PM   #6
I talked to this gentleman about his Symphonic Line preamplifier. i recomended this website to him for possible suggestions. it sounds to me by his description that one or more of the tubes have become microphonic. thanks....WCW III
william c waldecker 3rd
Old 19th February 2006, 05:09 PM   #7
Default Erleuchtung
Had a look at the photo inside the amp, think the inputs are buffered, some tubes near the inputs, maybe cathode followers.
Original the amp uses E88CC / 6922 and not 6N1 (600ma heater)
Reinhard
Old 19th February 2006, 09:03 PM   #8
RIP
pedroskova's Avatar
Default Re: Erleuchtung
Reinhard
If it's meant to run 6922's, I'm surprised that the heaters are even glowing. Under those circumstances, he may be getting cathode poisoning(?).
Akai GX 265D line voltage on line outs? ShorBird Solid State 11 26th January 2009 11:44 PM
Reference Line Preeminence 1B Remote HELP! dshortt9 Solid State 0 21st August 2005 05:28 PM
Reference Sound - Reference IC's? amirmk Solid State 0 26th July 2005 07:49 PM
Pros/Cons to an OB Dayton Reference line array with an IB sub? mazeroth Multi-Way 19 31st May 2005 03:40 PM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Page generated in 0.09845 seconds (75.32% PHP - 24.68% MySQL) with 10 queries
