diyAudio Sponsor
Old 14th February 2006, 07:18 PM   #1
rafaro is offline rafaro  Guatemala
Default 7788 tube mic preamp design
As some of you may know the 7788 tube is a high transconductance pentode stockpiled by the military but finally released about 8 years ago. The high transconductance should translate into being able to reveal finer nuances of sound in preamp designs. I have seen it being used as a first tube in phono amps circuits and also as a driver in SET 845 amps. But have not yet seen it used in a tube mic pre design where it should in theory give superior results compared to 12AX7, 6072 etc designs. Anybody come up with a circuit for it yet? On search here and elsewhere I have not come up with anything. Would appreciate help ifrom the tube Gurus here n designing a tube mic pre with this tube...do have some UTC tube input transformers available. Any advice suggestions appreciated.
Old 15th February 2006, 01:07 AM   #2
Brian Beck's Avatar
The 7788 is a superb tube. It should do well for a low-noise mike front end. I suggest you do a search here and elsewhere for one of the 7788-based RIAA stages that have been posted. Remove the RIAA equalization, adjust total gain for your application and there you go. Like all high figure-of-merit tubes, be careful about excessive grid current. Keep Va as high as Pa will allow to reduce this problem.
Brian
7788 Triode Curves dsavitsk Tubes / Valves 89 21st July 2011 09:27 PM
Low Voltage Tube Solidstate Guitar preamp design ... Minion Instruments and Amps 12 23rd April 2009 05:06 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
tube microphone preamp design ideas PRNDL Tubes / Valves 9 7th June 2008 05:43 PM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 15 24th November 2005 01:19 AM
Page generated in 0.06783 seconds (80.35% PHP - 19.65% MySQL) with 10 queries
