Vacuum Tube Pre O.C.L.
Old 13th February 2006, 06:35 PM   #1
gianmaria is offline gianmaria  Italy
Default Vacuum Tube Pre O.C.L.
Hi everybody!
Anybody knows a schematic of an all Vacuum Tube Pre amplifier, with no capacitor on the signal path?
What kind of solution has been implemented?
Thanks in advance.
Gm
Old 13th February 2006, 07:38 PM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
SY's preamp described on this forum. Any transformer coupled design. It's easy to avoid coupling caps but not necessarily cheap.
Old 13th February 2006, 08:46 PM   #3
On Hiatus
SY's Avatar
Actually, my preamp does have one coupling cap internal to it, though I eliminated the troublesome output cap. The input cap could be eliminated, too, by returning the servo output to the bottom of the transformer, but I think that's a cure worse than the disease; the input cap is pretty innocuous, but redoing the servo connection puts any servo errors and grunge right back to the input of the circuit.
One can do some level shifting to get direct coupling all the way through at the expense of complexity. I've played with it in the past and never thought is was even vaguely worthwhile.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 14th February 2006, 04:54 AM   #4
Looneytunes is offline Looneytunes  United States
Default Warning: NewB question
Sy,
What happened to the little chef? All this time I thought you were a child prodigy or something... heretical preamp with a little Frim Fram Sauce on the side.
Seriously (Sy or anyone) if cost weren't an issue, which would be the better choice for a simple preamp: a really good coupling capacitor or a really good input/interstage transformer? And who makes really good input/interstage transformers?
Thanks everyone.
Old 14th February 2006, 12:37 PM   #5
On Hiatus
SY's Avatar
I think that an input transformer brings a lot of benefits to the table. I'm much less convinced that there's a similar benefit/cost ratio for output transformers. And I hate big output coupling caps.
So far, I've tested Jensen and Cinemag 1:1 input transformers; both seemed excellent. I'm trying to get my hands on some Magnequest 1:1+1 units to give 6dB of gian in response to some requests. My guess, from testing other Magnequest products, is that they'll be first rate.
Old 15th February 2006, 03:29 AM   #6
Thanks SY
Old 15th February 2006, 07:06 AM   #7
Thank you to everybody!
Sorry, maybe I didn't post the question very well.
I meant a preamplifier with NO coupling capacitor e NO coupling transformer on the line path.
So, analog_sa, you got the question: could you help me to find the schematic of the mentioned SY's preamp?
Where do I have to look for?
Thank you in advance, G.M.
Old 15th February 2006, 10:05 AM   #8
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Look here.
A pic of my slowly progressing version...
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 15th February 2006, 10:16 AM   #9
On Hiatus
SY's Avatar
GM, the only way you can avoid having any transformer or capacitor is to have some level shifting. For example, if you use an ECC88 cathode follower with the grid at DC ground, the output will always be riding on a volt or three of offset- under the conditions that I run my CF, the offset will be 1.7V. So you can add 1.7V worth of battery or interpose an LED between the cathode and CCS, then pick the signal off the junction of the two.
In either case, the cure is much worse than the disease.
Old 15th February 2006, 01:22 PM   #10
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
One solution is to use a Russian 6XS7 double triode, as its unique cathode emissive material based on unobtainium allows complementary operation from inverted supplies. There is a problem in that the cathode is somewhat radioactive (Pu) and there would be a toxicity issue should the fragilium quartz envelope be compromised, but the minor hazard was considered acceptable by the designers. Besides, the problem is not appreciably worse than some of the Western Electric gas voltage references (cf 313C). Because of the complementary operation, the valve must be biased to stimulate electron emission and the lowest noise option is to do this is optically, using a GaAl laser with a wavelength of 465nm pointing directly into the cathode singularity. Obviously, optically stimulated emission requires that the valve (and laser) is enclosed in a light-proof box, and given the minor radioactivity noted earlier, it is advisable to make the box out of pure lead (999 purity minimum). The original application for the 6XS7 was in reactor control systems (cf Chernobyl).
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Vacuum Tube Pre O.C.L.Hide this!Advertise here!
Homemade Vacuum Tube dhaen Tubes / Valves 50 13th July 2011 05:48 PM
WTB: Vacuum Tube Tester mrdon Swap Meet 0 22nd May 2009 04:01 AM
S3E Vacuum Tube angsuman Tubes / Valves 12 15th March 2008 05:12 AM
The Vacuum Tube Truth Serratoga Tubes / Valves 31 29th November 2007 09:25 PM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
Copyright ©1999-2017 diyAudio
