Why no single triode OTL power stages? - Page 3 - diyAudio
Old 14th February 2006, 09:23 PM   #21
leadbelly's Avatar
Feel free to go away and start as many "Why OTL's stink" threads as you want.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 14th February 2006, 10:22 PM   #22
andrei is offline andrei  Canada
I guess you don't like hearing what I have to say. Sigh...
OK, if you are set to build SE cathode follower with a triode, check out 6528 tube. With two sections parallel, you get Gm = 47mA/V, Rp = 120ohm with mu = 9. Significantly better than 6C33 (Gm = 40mA/V, Rp = 130ohm, mu ~ 2.2) for cathode follower duty.
Old 15th February 2006, 08:13 AM   #23
Default 6c45
Hans,
Thank you for the reply.
Howabout using 4 x 6c45pi as CF output stage.
Ra=1.3K, Mu=52 Gm=45mA/V,R out=Ra/(1+Mu)/4
Is it correct the output impedance=6 Ohms
without NFB
Regards CHOW
Old 15th February 2006, 10:00 AM   #24
Yes it should be something like that but it will not give much power, max current is specified to 52mA for each tube or 208mA for 4 tubes in parallell, this only gives a output power of ~0.17W.
Much better to use feedback or even better to use a SEPP stage ala inverted Futterman, preferably with 6C33C.
There are better tubes "available" like the 6528 mentioned here but it seems to be made of unobtanium therefore discussing these rare beasts is more of an academic excercise.
Regards Hans
Old 15th February 2006, 10:25 AM   #25
Default 6c19
Dear Hans
I know 6c33c is out most suitable for OTL,
but 6c19 only cost for a few HK dollars from China,
And I got 40 of them, that's why I want to scratch the
SE1.5WOTL.
Regards CHOW
Old 15th February 2006, 05:27 PM   #26
If you want to use 6C19 you either need to use a lot of them or use feedback, I would use feedback and that is also obviously what Rozenblit is using in his SE OTL.
Regards Hans
Old 15th February 2006, 05:43 PM   #27
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
I don't want to water anyone's firework, but my understanding is that OTLs become more practical the bigger they are. You end up having lots of valves in parallel to handle the power and by doing so, you get a reduced output resistance even before feedback. However, I keep on wondering about a low power OTL using 6C45 in Class A2 with perhaps only 60V across them and driven by something beefy, another 6C45, or (dare I say it?) a source follower.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 15th February 2006, 07:01 PM   #28
It would work but it doesn't give higher output power as the allowed max anode current is only 52mA per tube. You can probably exceed this by up to a factor 2 if you can live with the shorter life but it would still only give very low output power as a CF.
The problem is not to get the tube to draw high current as such but to have reasonable reliability.
Regards Hans
Old 15th February 2006, 07:17 PM   #29
EC8010's Avatar
Oh dear, I just did a few sums and you're right. The 52mA limitation rather puts the kibosh on the whole idea.
URL collection of Single Ended Solid State Output Stages tiefbassuebertr Solid State 0 27th June 2009 07:53 AM
Power cord for single ended triode kimobuddy Tubes / Valves 1 11th April 2009 07:47 PM
Looking for low-ish rp single triode dsavitsk Tubes / Valves 19 5th January 2009 04:51 PM
Copyright 1999-2017 diyAudio
