diyAudio Sponsor
Old 12th February 2006, 08:27 PM   #1
Default Help with trafo
I am planning a SE amplifier based on KT88 tubes.
I was looking on www.ebay.de and found som trafoes from www.tubeland.de.
Does any know this trafoes?
How does they sound and so on?
Benny
Old 13th February 2006, 08:12 PM   #2
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
Which ones exactly? Could you link directly and also translate for us
But yes, you should definitetly do it
OPT Trafo Dynsdale Tubes / Valves 10 22nd March 2009 06:41 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
SE Trafo for PP use dsavitsk Tubes / Valves 15 8th August 2007 08:27 PM
Of what value is this trafo? wxn Parts 7 13th June 2005 12:08 PM
Trafo to buy for PWM amp partyjups Solid State 6 19th December 2001 10:32 PM
Page generated in 0.06968 seconds (68.69% PHP - 31.31% MySQL) with 10 queries
