diyAudio Sponsor
Old 11th February 2006, 04:55 AM   #1
andy2 is offline andy2  United States
Default Need recommendation for cathode bypass cap
The current value is 100uf/250V. Could someone recommend a good brand?
Old 11th February 2006, 07:50 AM   #2
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
I have used Nichicon Muse from angela.com before with good results.
That is quite a high voltage rating though, I wouldn't have thought it would need to be that high. What tube is it used on and what voltage is across it? If it is only a few tens of volts, you will be able to get away with a lower voltage rating.
Old 11th February 2006, 08:19 AM   #3
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
i would second the Nichicon Muse. I also used Panasonic Tsha and Black Gate Standard.
I would like to try film though, although a friend said that the Black Gate sounded better compared to a Solen on his Airthight 300B.
Old 11th February 2006, 02:17 PM   #4
Can you use bipolar cap for cathode bypass? I think the one in the amp is unipolar.
Old 11th February 2006, 05:18 PM   #5
I suspect that by "bipolar" you mean a non-polarized cap, like a film cap without "+" and "-" terminals. Yes, you can use a non-polarized cap.
Old 11th February 2006, 05:47 PM   #6
rdf is offline rdf  Canada
rdf's Avatar
If chassis permits also consider a polyprop and oil motor run cap. Relatively cheap and excellent quality:
http://cgi.ebay.ca/100-uF-Oil-Run-Ca...QQcmdZViewItem
If you decide on this route and it's important to you, this version of ASC sold by the above E-bay dealer has non-magnetic electrode terminals. The terminals of the domestic ASCs I bought from Digikey are strongly magnetic.
Old 11th February 2006, 05:54 PM   #7
Tube_Dude's Avatar
I think that is to big and then susceptible to stray noise pick up...only for a output stage, I'm afraid.
In some positions ..."size matters"...
Jorge
Old 11th February 2006, 06:10 PM   #8
rdf's Avatar
"I think that is to big and then susceptible to stray noise pick up...only for a output stage, I'm afraid."
Not at all! The internals are shielded and the terminals are actually quite close together, about 1/2" solder to solder between the inner tangs. Conicidentally I type this while listening to a single stage headphone amp using exactly those caps in an Ultrapath position around a very high transconductance triode, the 6C45-PE. Keeping in mind Ultrapath is reputedly more prone to PS noise than typical layouts the noise spectrum of this circuit constructed on open plywood looks like (hot off the press ):
(post edited for multipull spalling errurs)
File Type: png 100 uf asc motor run in ultrapath circuit - noise.png (7.7 KB, 290 views)
Old 12th February 2006, 07:47 AM   #9
Shifty,
Here is the schematic.
http://www.geocities.com/hai_vu1/schematic.JPG
I am not familiar with tube amp so not sure why the rating has to be that high. The amp uses two 300B per channel which results in 22W.
Old 15th February 2006, 01:46 AM   #10
Hi andy2 ,
I saw the schematic diagram of your amplifier , and the value of cathode by-pass caps of output tubes is absolutely correct .
You can try another brand to see if it results in the sound's improvement . but don't try to change the rating ( uf and WVDC ) .
Try to use brands like Nichicon , Nipon Chemical , etc.
Carlos
2A3 without cathode bypass cap??? papparazzi Tubes / Valves 13 25th May 2008 04:06 PM
Which BG cap best suited for cathode bypass? reaction Tubes / Valves 10 25th April 2005 07:43 AM
Polyprops as cathode bypass s2kov Tubes / Valves 10 3rd December 2004 08:56 PM
Cathode bypass cap ? woody Tubes / Valves 2 19th May 2002 05:53 AM
Best Cathode Bypass Cap Mohan Varkey Parts 4 6th May 2002 08:59 PM
Page generated in 0.11214 seconds (77.25% PHP - 22.75% MySQL) with 11 queries
