| diyAudio Sponsor | ||
#11 |
Here are some pictures. I have perhaps the worst digital camera ever, so hopefully the quality is enough that people can see what is going on.
Anyhow, there seem to be several noises at any given time, and depending upon the tube they are at different levels. I think the hum/buzz noise is at 120Hz as it doesn't sound low enough to be at 60. It is pretty constant even with the volume all the way down. Could be 60, though? Some of the other noise is clearly banging in the tubes due to heat. With the volume down, the tube itself is hissing and sounds like springs being tapped. With the volume up this all comes through the speakers. One of the tubes (a sylvania) makes a loud screak -- not high pitched exactly, but higher than the hum -- maybe at 240Hz or 480Hz? Anyhow, some pics. |
#12 |
inside
#13 |
inside close-up
#14 |
back
#15 |
Here's the PS schematic. There are actually 2 of these. When I started, I thought I was going to run this at 80-100mA which was going to require the 2 power supplies. I subsequently backed off on that, but since I'd already drilled the holes and bought the parts, I left them both thinking I might need to adjust the curent up at some point.
#16 |
Try one 100uF electrolytic cap in parallel with the two Leds ( one cap only across the 2 Leds ).
But I also suspect , a grounding schema issue.
Jorge |
#17 |
One thing that immediately jumps out at me is the separation of the power supply grounds. The loop around the transformers, diodes and filter caps carries a boatload of ripple current. You don't want anything grounded within this loop. C3, C4 and the transformer CT should all meet at one point, and that point be the far end of the ground bus. The output stage should be returned directly to that junction point.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#18 |
Here's how I did the grounding in case there is something obviously wrong:
Each PS has a star ground where the ground side of the PS caps connect. The center tap of the high voltage winding also connects to the same point. each cathode connects to its own ground (through a resistor and cap). These are connected together, and both of the PS ground positions connect to one of these spots. The volume pot and the input and output ground also connect to this spot. The CCS grounds and the filament transformer center tap also connect to this spot. This spot is connected to the chassis plate at one leg of the filament transformer. The other leg of the filament transformer connects the chassis plate to mains earth. |
#19 |
Right under the JJ caps there is a point where all three caps and the CT are joined. By loop, do you mean the loop of wire that is the center tap wire?
#20 |
You have audio travelling on a pair of twisted wires. That might work if one was earth, but you appear to have twisted left and right together. At the very least, that will cause crosstalk. You also appear to have some of these wires passing near the mains transformer. That will cause hum. I hate screened lead and normally make my audio wiring sufficently short not to need it, but I think you're going to have to resort to it to get rid of the hum.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| Noisy CDM | Scorpio(DDMF)! | Digital Source | 6 | 25th February 2010 01:50 PM |
| Noisy Amp | vento | Solid State | 13 | 16th January 2009 09:45 PM |
| noisy rectifier tube | soundbadger | Tubes / Valves | 3 | 13th April 2008 10:38 AM |
| Noisy PSU? | pftrvlr | Tubes / Valves | 16 | 2nd July 2007 07:26 AM |
| help on P1.7 (Noisy) | pamaz | Pass Labs | 9 | 26th August 2004 03:21 PM |
| Page generated in 0.13397 seconds (82.40% PHP - 17.60% MySQL) with 11 queries |
