| diyAudio Sponsor | ||
I'm trying to build a SE 6as7 but i'm having some problems. Main reason is the driver tube- a 6sn7. OK the output stage is solved, i am running the 6as7 with 250 volts at the plate(maximum allowed according to data sheet) and low current and i am getting a lot of power (good) but i need a good sounding driver stage... I tried direct coupling , SRPP and 12at7 to 6sn7....i didn't like any of them As i said before the driver is a 6sn7...why? Because i like them and got them cheap. The 6sn7 needs lots of volts hence my 330V B+. Yes i know, too high for the 6as7 but i also got them cheap. Then i found this schematic... http://www.jogis-roehrenbude.de/Lese...7/Endstufe.gif I've never tried a CSS but it seems to me a great idea for this amp. I am not paralleling the 6as7's (don't need many watts) but i want to copy the driver stage. I have bought all the parts for the ccs but now i am in doubt: - does it have to be same B+ or it could be 20 volts more or less. -the LED and the diode in the schema...can i use any diode, any LED? Any other advice about ccs's welcomed... i know very little. |
#2 |
The LEDs can be anything, but you have to know their forward voltage to properly calculate the emitter resistor. There are whole masses of posts here about just that subject- a few minutes searching ought to turn up all the formulas and schematics you could ever want.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#3 | |
Progress so far. Wine box. |
#4 |
It doesn't work. 0 volts at the 6sn7 cathode. No music, nothing,nada.
CCS= 310 VOLTS IN, 307 VOLTS OUT. LED's light up. What could be wrong? If i had miswired a transistor would i get 307 volts at the plate? Any ideas for troubleshooting the circuit? |
#5 |
Clearly, there's no current being drawn. Disconnect the CS from the tube and verify its operation- from the CS to ground, connect a 20K resistor. Is there 200V across it? If so, the CS is working.
Most likely, you've got a wiring error.
#6 |
Thanks SY, i get 232 volts with a 22k resistor to ground.
Is it working? |
#7 |
It works ....10v at the 6sn7 cathode.
Thanks again SY. |
#8 |
What operating point have you chosen for the 6SN7?
Cathode resistor value? Kevin
www.kta-hifi.net |
#9 |
His schematic is linked in the first post. 10mA, 1k cathode resistor.
I wouldn't go that route, but it's not my design.
#10 |
Hi Sy,
What do you think of the operating point chosen? I suspect that there is very little voltage headroom to spare here.. Imho this seems like a good place to try transformer coupling if he was so inclined...
www.kta-hifi.net |
| 6SN7 pre-amp | Andersen | Tubes / Valves | 57 | 17th July 2011 07:00 PM |
| SE 6SN7 amp.... | JandG | Tubes / Valves | 24 | 6th March 2011 12:37 PM |
| 6sn7's | irishguy170 | Swap Meet | 0 | 15th January 2008 08:09 AM |
| Help me.......What is the 6SN7 ??????? | cd149dc | Tubes / Valves | 10 | 17th June 2007 05:09 PM |
| Is it the 6SN7 or me? | arnoldc | Tubes / Valves | 4 | 13th October 2006 12:31 AM |
| Page generated in 0.10590 seconds (76.41% PHP - 23.59% MySQL) with 11 queries |
