| diyAudio Sponsor | ||
#11 |
Try a cathode follower to drive the 6AS7. You might need an extra gain stage at the front end. I found a cathode follower ideal to drive my SET.
Cathode followers are grunty and easy, and give mad bass
#12 |
Kevin and Shifty: i'm really open to ideas. I need a driver stage with 6sn7's, that's all.
I've tried driver stages for 300b's. Angela 300b driver stage sucks with the 6as7 IMHO. Great detail but thin sound. Audio note srpp ....not my taste. So far best sound was with an ef184/6ej7 triode connected to a 6sn7 grounded cathode stage. I have a preamp. I might try a 6sn7 grounded cathode stage to a 6sn7 cathode follower. About the schematic i posted: css didn't work. Voltages are ok but when is time for the music...oh my! Volume up and down, scratches, weird noises...etc. Voltages do not oscillate. Everything is allright, only i could have mistaken the emitter for the collector but i doubt it. Emitter is the one with the arrow pointing to the transistor right? |
#13 | |
What I also see as a potential problem with this circuit is the high 2nd harmonic you'll get from the combination of the plate CCS and the unbypassed cathode resistors. Now, it is possible that the designer was being fiendishly clever and using this to counteract the 2nd in the output stage, but if we look at that first stage in isolation, I'd expect pretty high distortion at the required swing.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#14 |
#15 | |
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#16 |
Now this is getting funny. I did recheck and tried again the ccs and i don't know what i have built but i know it's weird. It kills some musicians and keep others...i only heard the drummer in the last song... sometimes voices come in and then disappear... all with some scratchs now and then as if a crazy dj had remixed all my cd's.
One thing i have noticed: the 150k resistor to ground(1 watt) gets too hot, i am going to change it to 2 watts, is this normal? |
#17 |
normal you need 150k 2 watt
check my schematic |
#18 |
Hi Jeapel,
your ccs looks just like mine except for those 2 diodes (1n4004, 1n4148), guess they are there to make the circuit safer. My ccs works, there is a constant current but when AC comes to play i hear a lot of problems....with a plate resistor the circuit works fine. It must be a transistor...maybe faulty. I looked at your driver stage. I could do it but any reasons to do so? I will need another power supply or is the 6as7 cathode dropping 150volts? I have several options, being a cathode follower the best one at the moment. Thanks for your answer...yes 2 watts. |
#19 |
The CCS circuit was fine, it was the current (too much), i lowered it to 5mA and now works like a champ. Thanks to those who helped.
#20 |
attention here :-)
-jogis use led(light diode) for diode and voltage drop is 1.7v ccs= (1.7 - .7)/100=10ma -in my case i replace led by 3 x 1n4004 and voltage drop is 3 x .7=2.1 ccs=(2.1- .7)/240=5 to 6 ma -1n4148 is for transistor protection -jogis use 10ma for 2 x 6sn7 5ma for each tube -normal bias for 6sn7 is around 2 to 5 ma 10ma is limit -don t forget for any tube to my opinion ?? for driver stage must be around 25 to 30 % of pa max. (in watt) for output stage must be around 60 % of pa max. it s for best tube life check volt across tube X current tube = watt pa max. is plate dissipation maximum 6as7 is 13 watt max. if i remenber well |
| 6SN7 pre-amp | Andersen | Tubes / Valves | 57 | 17th July 2011 07:00 PM |
| SE 6SN7 amp.... | JandG | Tubes / Valves | 24 | 6th March 2011 12:37 PM |
| 6sn7's | irishguy170 | Swap Meet | 0 | 15th January 2008 08:09 AM |
| Help me.......What is the 6SN7 ??????? | cd149dc | Tubes / Valves | 10 | 17th June 2007 05:09 PM |
| Is it the 6SN7 or me? | arnoldc | Tubes / Valves | 4 | 13th October 2006 12:31 AM |
| Page generated in 0.12353 seconds (80.26% PHP - 19.74% MySQL) with 11 queries |
