diyAudio Sponsor
Old 9th February 2006, 06:31 PM   #1
poynton is offline poynton  United Kingdom
Magneto the Gravity Man
poynton's Avatar
Location: A life on the ocean waves when I'm not at home in N. Wales (but I'm not Welsh so no sheep jokes!)
Default HT regulator using 78xx
Hi.
Can a 78xx ( or other cheap regulator) be used to regulate a voltage of around 200v for a valve preamp??
or is a high voltage transistor with zeners adequate?
I'm not looking for anything sophisticated - just simple and working.
Any help appreciated.
Andy
Old 9th February 2006, 06:33 PM   #2
SY's Avatar
The 317 is suitable and cheap. Go to the National Semiconductor site and search for the applications note on this from Michael Maida.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 9th February 2006, 06:39 PM   #3
triode_al's Avatar
yes, as the thing is purely floating.
Though use a diode (250 PIV) across the unit as a safeguard against the countercurrent if the feeding supply might get lower than the destination...
I used this already in 1984!
It will give around 5-10 mV ripple/noise.
You can put a small capacitor on the voltage intersection (100 nF) to reduce noise. But then also this must be brigden with a diode to the destination to ensure the "ground termminal" never is higher than the Vout or the unit will break down when the output goes down too fast.
Whether the simple zener/transitor is ok depends on the feed: often a zener will hardly be 'quiet'.
See my 2SK175/2SJ55 F5.. CS8412/SAA7220/TDA1541 ; SP-6 Light ; MC30 Super--> two stage RIAA 2SK240-ECC88/6SL7.
Old 9th February 2006, 06:50 PM   #4
poynton's Avatar
Hi.
OK guys - enough info for now!!
Thanks for the quick replies - much appreciated.
Andy
really dumb 78xx/79xx regulator question bluesmoke Parts 12 16th December 2006 08:06 PM
best sounding 78XX/79XX drop in Regulator Replacements? ThorstenL Digital Source 66 18th October 2006 05:59 AM
317 vs 78xx Leolabs Solid State 2 20th March 2006 04:37 AM
Page generated in 0.07685 seconds (70.83% PHP - 29.17% MySQL) with 10 queries
