| diyAudio Sponsor | ||
Friends!
My new madness is to do it myself in making a SE triode amp (3w)! And I badly need help: a schematic, a part list for something simple, cheap that should give nice results with a pair of Fostex full range drivers. Thank you very very very much! TTA |
#2 |
Cheap and simple 3W SE DHT, hmm...
2A3 or 6B4G (Sovtek single plates), Hammond 1627SE OPTSīs, a simple RC-coupled triode input/driver stage and a tube rectified CLC power supply. 2A3 should work with AC filaments but 6B4G needs DC heating to avoid hum. |
#3 |
Is 3 w enough - how many dB are your Fostex ?
#4 |
A popular choice- JE Labs 2A3 in two flavors. One is at www.angela.com site.
#5 |
If DHT is not mandatory, costs can be held down by using a triode wired multigrid tube. 6AQ5s are inexpensive and 12AQ5s even more inexpensive, but not as plentiful. Either 'AQ5 variant will do fine driven by 1/2 of a 5965. Hammond 125ESE O/P trafos are about as low cost as can be, while offering OK performance.
SS B+ rectification by UF4007 diodes combined with a low cost snubber network is quite good sounding and will cost less than vacuum rectification.
Eli D. |
#6 |
#8 |
They don't come much simpler than this: http://www.the-planet.org/6EM7.html You could also, as Eli said earlier, sub in ss diodes. If you do that, you might want to reduce the power transformer voltage about 10%.
Or this: http://www.enjoythemusic.com/magazin...2/levinson.htm Either of these will give a watt or two. Depending on the size of your room, may be plenty. Sheldon |
#9 |
Friends,
Thank all of you that have tried to give me a hand. What I've got in this moment is a pair of Russian made 6C33C. The wonderamp that I'll build around these tubes should make a pair of speakers made based on Fostex FE 206E drivers following the producer's cabinet design. Again advises, suggestions, schematics etc. needed. Thanks a lot and best regards, TTA |
#10 |
Oh, sorry!
I wanted to say that the amp should make the speakers sing. Nicely and safely! TTA |
| Da 42 Triode | exurbia | Tubes / Valves | 8 | 16th October 2008 10:57 PM |
| DIY triode | DSP_Geek | Tubes / Valves | 2 | 10th September 2008 05:03 AM |
| Another 3f4 spice triode model: 5718 submini triode | wa2ise | Tubes / Valves | 0 | 5th September 2008 04:31 AM |
| PP-Triode , PP-UL , PP-Pentode-strapped-as-Triode | percy | Tubes / Valves | 23 | 22nd January 2007 12:36 AM |
| newbie post, but hopefully not a newbie question | wiredcur | Solid State | 3 | 24th August 2002 10:49 PM |
| Page generated in 0.09439 seconds (79.21% PHP - 20.79% MySQL) with 11 queries |
