| diyAudio Sponsor | ||
#81 |
Bias supply:
#82 |
Sorry i dont understand that either. I've never built amp before i dont even know what is a b-.
But the info you got there look like to set a good individual bias for each driver tube but dont talk about EL34. Is that bias gone to work whit those. By the way the link i sent you also have your amp on ebay just do a search for bogen. |
#83 |
If you want an internal picture of the same amp I have on ebay here it is. The amp is working.
#84 |
Okay, I was looking at some other circuits and got to thinking, why can't I just change the cap and resistor values to change the voltage? This is what's reccomended on the Triode Electronics site for the Quiksilver 8417 amps, why not the Bogens? I think it would be much easier then cramming in more stuff.
I also found a thread on here about a guy having identical problems as me, low volume with what sounds like preamp distortion. It turned out to be a problem with the tone controls, he recapped them and it fixed the problem. I might order some replacement caps for my tone stack too. how do i figure out what's wrong with this (vintage) amp Also, an MX-60A popped up on ebay and it just looks like an M60A with extra inputs. |
#85 |
Although I'm not getting much input here anymore, I'll at least say that I got the tubes tested. The 8417s check out good with similar results. The 7247 is in incredible shape, from how it looked on the tester I think it will outlive me.
Strangely, the 6EU7s tested completely dead, but this can't be the case because they light up and I was getting sound so they obviously can't be dead. |
#86 |
Hi Darren,
I agree. If the filament lights you will get some kind of reading on at least one tube. Test them in circuit by measuring the plate voltage and also the DC voltage across the cathode resistor (to figure out the current draw). I really wouldn't worry about it unless you have changed the coupling caps and have no/low signal. -Chris |
#87 |
The 6eu7's of the m60a amp I just sold had a bad set of 6eu7's that I replaced. A bad tube may still light up. The cause of a bad tube may be the result of leakage. That is why one of my tubes was dead. That may also be the cause of why you had that loud noise when using the amp. On another amp I had the 7247 had leakage and it caused a lot of noise and half the tube was dead and the tube filament was working just fine. I also have some 8417's that were used alot and are almost dead and still fire up. Also did you make sure to test both plates of the tube?
#88 | |
That's why sometimes it's best to troubleshoot the tube in a known good circuit. -Chris |
#89 | |
The needle was as far the the left (bad) side as it could go for both tubes, due to the strange pinout of the 6EU7 it could have just been a matter of his tester not being set up for them. The "loud noise" I heard sounded awfully like an explosion of some sort, could that be a result of leakage? On another note, I got adventurous (or stupid, take your pick What puzzles me is that if there's no hum, and all the voltages are fine, what could have exploded? -Darren |
#90 | ||
I've had tubes that light up but are dead. Or at least one triode section. Since you know it is dead, don't use it. I haven't looked at your schematic but when I was debugging my HK PA amp (with help from this forum) I was able to bypass the tone stack for initial testing. Once you get your new parts installed, hookup a load (old speaker), short the inputs and measure every pin on every tube. Post voltages. I like Va for plate voltages, Vk for cathode voltages, Vg1, Vg2, ... for grids. Don't forget to check heater voltages. My HK used the heaters for the driver tubes to bias the output tubes. I pulled the mic driver tubes so the output tubes were not getting biased. This threw me off until more wiser members straightened me out. We can start looking at suspect voltages (input grids should be zero or less), cathode biased sections should fall within spec, ... rick |
| Bogen M330A Tube PA Amp for Guitar | zeke | Tubes / Valves | 28 | 6th December 2009 06:58 AM |
| bogen mx-60a tube pa amp guitar | ElectricMan | Swap Meet | 1 | 3rd May 2009 02:02 AM |
| Bogen J130 PA to guitar amp? | bigaldo | Tubes / Valves | 0 | 18th February 2008 04:36 AM |
| Bogen H-30 guitar mod | tgrizzle | Tubes / Valves | 5 | 14th April 2007 10:50 PM |
| Bogen K15 convert to guitar amp | tonemonster | Tubes / Valves | 0 | 29th March 2007 08:11 PM |
| Page generated in 0.12899 seconds (79.16% PHP - 20.84% MySQL) with 11 queries |
